1. digitalfreaknyc's Avatar
    I purchased 3 of these on ebay and, for some reason, they're really wonky with the Sammy. They'll charge 100% and then when I disconnect the charger, it will only show 85% charged in the phone. Anyone else have one of these and the phone has problems showing the extra amount? Is it a OS problem?
    08-27-2012 05:51 PM
  2. samanthanielquel's Avatar
    Restore your device to defaults with the 'Factory Reset' option.
    08-28-2012 12:58 AM
  3. digitalfreaknyc's Avatar
    Why on earth would I do that??? Wiping the phone has nothing to do with the battery...and it works fine when I put in the OEM battery.
    08-28-2012 03:01 PM
  4. eagle63's Avatar
    I wouldn't trust any cheap batteries from ebay. Not only can they cause weird problems, but they are almost never the mah that they claim they are. Even when they come from reputable companies like Seidio they never perform as rated.
    Sent from my SGH-T999 using Tapatalk 2
    08-28-2012 11:01 PM
