Results 1 to 2 of 2
- 07-31-2012, 08:03 AM
Thread Author #1
S3 need help with connecting to PC and Go SMS pro
Just got the S3 and can not connect it to windows PC. Has anyone had that problem?
and downloaded the GO SMS PRO app.. can't get the smileys from Iphones.. is there a setting or something that needs to be changed.
I appreciate any help from the forum
Thanks - 08-03-2012, 08:53 PM #2
Re: S3 need help with connecting to PC and Go SMS pro
For go sms pro you'll need to download the emoji plug in from the play store... after that you'll have the extra smileys
Haven't tried to connect mine to the computer except to charge yet... i've used kies over wifi to transfer pics etc...
Reply
