1. zakassam's Avatar
    So I just moved into my house and I dont get any service at all so im completey 100% dependent on Wifi Calling. I have a cisco e1200 router and i just replaced it with an asus n53, which im not using as a repeater to get better reception in my room and living room. What im looking for is a solution for my wifi calling going in and out all the time.Wifi Calling cannot consistently just be on. every five minutes or so it will reset. I turned the wifi power saving mode off by pressing the Star, Pound, 0011, Pound option but doesnt have seen to make a difference. Also Before I made that power saving change, ive been told ive been missing a lot of calls and the phone does not ring for the life of me. Please help! Im not sure if i need to choose a different wireless security mode but its at WPA2 right now.
    Thanks
    11-20-2012 11:15 AM
  2. GTWalling's Avatar
    There is a known issue with the current Wi-Fi Calling app. It will go straight to voice mail. T-Mobile has been working on a fix since "August". Go figure. You may qualify for a T-Mobile booster. Contact Customer Support and talk to them.
    11-20-2012 07:46 PM
  3. danbutter's Avatar
    Same issues here. It will say invalid certificate and not work at all or sometimes it will work, but mostly only on outgoing calls. Incoming calls usually ring a half ring and then done. I think I have been able to answer about twice. Even when I call out I can't go very far from the router before it starts yelling at me that signal is dropping
    11-21-2012 02:41 AM
  1. Wifi calling issues
    By Starfinder in forum T-Mobile Galaxy S III
    Last Post: 02-09-2013, 06:26 PM
  2. [How-To] Wifi calling on CM7 (T-Mobile only)
    By Jerry Hildenbrand in forum Google Nexus One Rooting, ROMs, and Hacks
    Last Post: 01-10-2013, 05:24 AM
  3. Optimus V WiFi, Data Download & 3G Connection Issues
    By dgm_sf in forum Virgin Mobile Optimus V
    Last Post: 05-31-2011, 10:10 PM
  4. Is a skype call on wifi if I'm connected to wifi?
    By Clocks in forum Sprint Epic 4G
    Last Post: 03-04-2011, 11:30 AM
  5. Wifi calling on t-mobile g1 check out my video.
    By add119 in forum T-Mobile G1
    Last Post: 11-21-2010, 03:05 PM
