WiFi hotspot problem. Help!
jurr
8
I can't turn on the hotspot function but it did work in the past. Every time I try it just goes back to off. Does anyone else have this problem or know how to fix it?
Sent from my SGH-T999 using Android Central Forums
jurr
8
Re: Wikipedia hotspot problem. Help!
I don't live in the us so I don't have an t-mobile plan.
sagarmpatil
I have exact same problem.. I have T-Mobile S3 (SGH-T999) bought from US and I am in the UK on 3 Network. For some reason I am also not able to turn on the WiFi hotspot. As soon as turn it on it automatically goes to OFF. I rooted my device, still no go.. installed WiFi tether app but still no go. I need this to work desperately.
Any help to get this resolved is much appreciated.
cheers!
SP
jurr
8
Which WiFi tether app? I downloaded foxfi and it works for me
Sep 8, 2011
9
This is because it is blocked. If you have a Tmobile gs3 tmobile has worked with Samsung to block it unless you have a tmobile hot spot package on your account. Since you are not in the US and don't have Tmobile this is a problem for you.
I would suggest using foxfi to bypass the standard hot spot app.
yurais
3
my problem is that for hotspot to work phone must be connected to Mobile Data, if mobile Data is not connected hotspot will not get enabled.
I know you will say: what are you planning to do with a hotspot if not sharing your mobile data line ?
well, I would like to enable the hotspot without enabling de data, and enable teh data when I need it, thus keeping the connectivity across equipoments connected to the hotspot.
MarcosVo
