Results 1 to 7 of 7
    jurr's Avatar
    Posts
    Default WiFi hotspot problem. Help!
    I can't turn on the hotspot function but it did work in the past. Every time I try it just goes back to off. Does anyone else have this problem or know how to fix it?
    Sent from my SGH-T999 using Android Central Forums
  2. #2
    Default Re: WiFi hotspot problem. Help!
    Do you have a the Tethering and Mobile Hotspot add to your T-Mobile plan?
    SGH-T999
    T-Mobile USA
    Rooted Stock 4.1.1
    If My post has helped please hit the Thanks Button.
    Unused Ram is Wasted Ram
    jurr's Avatar
    Posts
    Default Re: Wikipedia hotspot problem. Help!
    I don't live in the us so I don't have an t-mobile plan.
  4. #4
    I have exact same problem.. I have T-Mobile S3 (SGH-T999) bought from US and I am in the UK on 3 Network. For some reason I am also not able to turn on the WiFi hotspot. As soon as turn it on it automatically goes to OFF. I rooted my device, still no go.. installed WiFi tether app but still no go. I need this to work desperately.
    Any help to get this resolved is much appreciated.
    cheers!
    SP
  5. #5
    I may be wrong but I don't think it will work without being on a T-Mobile network.
    SGH-T999
    T-Mobile USA
    Rooted Stock 4.1.1
    jurr's Avatar
    Posts
    Which WiFi tether app? I downloaded foxfi and it works for me
  7. #7
    This is because it is blocked. If you have a Tmobile gs3 tmobile has worked with Samsung to block it unless you have a tmobile hot spot package on your account. Since you are not in the US and don't have Tmobile this is a problem for you.
    I would suggest using foxfi to bypass the standard hot spot app.
  1. My phone reboits when I enable portable wifi hotspot. Please help....
    By DSDCreations in forum Samsung Galaxy S3 I9300
    Last Post: 12-08-2012, 08:58 AM
  2. help wit wifi hotspot
    By strawhat nito0890 in forum Sprint Photon
    Last Post: 07-18-2012, 04:21 PM
  3. Major problems with wifi hotspot tethering
    By UNCMo96 in forum Droid RAZR
    Last Post: 04-15-2012, 08:02 AM
  4. Need help with tethering/ wifi hotspot please...
    By Walter E Kurtz in forum Sprint Photon
    Last Post: 12-31-2011, 09:38 PM
  5. Has HTC fixed the WiFi hotspot problems?
    By FinalJenemba in forum Verizon HTC Thunderbolt
    Last Post: 09-13-2011, 02:04 PM
