Page 3 of 3 FirstFirst 123
Results 51 to 63 of 63
Like Tree7Likes
  1. #51
    shaddou's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Samsung Galaxy S3 doesn't connect to wifi with strong signal.
    Thanks for The Tip, Added a static IP with a .253 address and it worked like a charm
  2. #52
    korleis69's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I have been done all that but my S3 is still the same. Can some one tell me because of the Mainboard and what chip is damage??
    Thank you
  3. #53
    dperez0706's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by tamarbeck1 View Post
    Please help. I've tried all of the things suggested here. My problem is that my phone will not connect to any wifi unless I am standing close to the router - as soon as I move away it loses the signal completely. All other devices, iPad, laptop etc. connect fine. I've spent a few days shouting at Virgin Broadband as I thought it was the new broadband I've just had installed, but came into the office today and had the same problem. Something else I should tell you - I did not have this issue until I for my phone back from the repair shop with a new screen! Any help/advice would be much appreciated!
    im having the same problem i did some research and i believe it could be a problem with the antenna when the guy disconnected the screen to replace it. he probable didnt connect the antenna correctly
  4. #54
    sanmiccarcha's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    This was so easy to do and it worked. Thanks for sharing.
  5. #55
    JAlyssa Quizora's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    this worked well with me.
    thanks!
  6. #56
    Tassie Mark's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Problem Solved.
    My Phone & my partners phones are both identical Galaxy S3's Hers connects with 5 bars when 10 foot from the router. Mine connects with 1 to 2 bars at the same range.
    After removing the rear cover of my phone I proceeded to remove the black plastic motherboard cover (approx. 10 screws. Please google process to avoid damage). The motherboard cover contains the wifi antenna.
    Note:The antenna is a piece of flexible copper on the back of some black PVC tape with the contact pushed through a slot and folded into a receptacle on the inside of the cover.
    I then held the battery in position by hand and switched on the phone. Signal strength was again observed to be as weak as before but not any weaker! "ah ha" I thought, "If the antenna makes no difference, it cannot be connected, when the motherboard cover is screwed back in place".
    I inspected the tape antenna stuck to the motherboard cover and found it to be a little out of alignment. A small hole punched into the tape didn't quite line up with the plastic dimple on the inside of the cover plastic. I proceeded to completely peeled the tape antenna off of the back of the cover and after pulling a little on the exposed metal connector to unstick a little more copper off of the tape. I re-seated the antenna so that the exposed metallic side of the antenna was seemingly better lined up with the metal spring contact on the motherboard. I also ensure that the teeny little dimple did in fact poke through the small hole at the end of the tape.
    When the cover was replaced. Voila! the signal strength was excellent. I didn't even need to use the power saving mode suggested by all other newsgroups. It was just a simple electrical connection fault. 5 Bars all over the house except for the Laundry where the phone achieved 4 bars.
    HTH
  7. #57
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Video coming shortly
  8. #58
    Chirag Mayani's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having same problem with my S3. I understood the location of the antenna on black cover, but want to know the procedure what you did. If possible, please upload the video/share link of the video.
    Thanks
  9. #59
    YoungGypsi's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I want to personally thank you so much. For 3 days after receiving a new modem I couldn't keep a signal at hm. Called my providers no help, then Samsung.... another brick wall that would cost me 70 + $ if I chose to send it in for repair or updates. Seeing I wasn't willing to pay them anymore for what I could in turn find the solution online. I tried everything an nothing seemed to help till your post. Tytytytytytyty!!!!!! As soon as I hit save I've had full signal strength an no drops. An all It took was a bunch of numbers actually a dot that had everything a mess. Wonderful help.
  10. #60
    jude111's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you thank you thank you! That worked on my 4 year old Samsung Galaxy 3 mini - first time I've had a problem which is really odd, but I followed your set up steps and I'm connected to wi-fi again. Cheers
  11. #61
    Emran Hossain's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Samsung Galaxy S3 doesn't disconnect to wifi and Data connect
    I am Emran from Bangladesh. I am using Galaxy S3 mini about 1 years. recently i have facing some problem that my devise do not off WiFi and data connect. when I off or disconnect the service then after a few moments it's auto connect with WiFi and data connect. please solution me how can i solved this problem
  12. #62
    Jeffrey Parriott's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    When I did this, I couldn't 'save' the information, when in the 'settings' in WiFi! I know I've tried this before and it seemed to work, this time not so much!
    Jeff
  13. #63
    Jether Ramos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    boom commended
  1. my Galaxy s3 will not connect to Mac
    By Matt Adamski in forum Samsung Galaxy S3
    Last Post: 09-11-2013, 10:22 AM
  2. Replies: 0
    Last Post: 03-19-2013, 12:16 PM
  3. Galaxy S3 will not connect to any WiFi network
    By Becciboo81 in forum T-Mobile Galaxy S3
    Last Post: 01-23-2013, 06:24 PM
  4. Samsung Galaxy S3 taking 30 seconds + to come out of sleep mode
    By shadoWyld in forum Samsung Galaxy S3 I9300
    Last Post: 11-02-2012, 06:58 PM
  5. Samsung Galaxy Tab 10.1 16 GB Wifi (with Samsung Case)
    By soccerfon711 in forum Marketplace Archive
    Last Post: 09-17-2011, 10:26 AM
