DEAL OF THE DAY: Save 43% on the Seidio SURFACE Case (with kickstand) for HTC One!
Results 1 to 8 of 8
    Question Problems connecting to VPN. Please help.
    So I'm overseas and I need to virtually appear in the US to access some sites and other stuff. I have been trying to connect through a VPN on my Sensation, but no luck. I am using VPNfire.com, which I use on my iPad and have no problems. Why is this not working on my Sensation? I can't figure it out at all! I've tried everything PPTP, L2TP... nada.
    Anyone else successfully use a VPN on your Sensation?
  2. #2
    ragnarokx's Avatar
    Posts
    Global Posts
    8,674 Global Posts
    ROM
    N4: MMuzzy, N7: SlimBean
    Default
    You'll need root access. See this thread to get VPN working:
    Sent from my Bulletproof Sensation 4G
    Default Re: Problems connecting to VPN. Please help.
    Quote Originally Posted by ragnarokx View Post
    Wait, wait, wait... So a regular VPN won't work on a standard Sensation? I don't get it? Why is it even there? SOOO confused.
    Thanks for replying, btw.
  4. #4
    ragnarokx's Avatar
    Posts
    Global Posts
    8,674 Global Posts
    ROM
    Default
    Quote Originally Posted by fasst27 View Post
    I'm not a VPN user myself, but read through that thread to get an idea of your situation.
  5. #5
    s0nic69's Avatar
    Posts
    ROM
    Stock
    wait, are you trying to use your phone to connect you a vpn source in the US, or are you trying to vpn into your phone (which is located in the US) ?
  6. #6
    marksmith29's Avatar
    Posts
    Global Posts
    6 Global Posts
    Well i had face the same problem while connecting my Sensation on VPN... but somehow i got the solution of it. I will give you the details
  7. #7
    Posts
    Global Posts
    6 Global Posts
    So, here i come by bringing some good information for you. I search around regarding your query and found a very interesting article which will definitely help you to configure VPN on your HTC Sensation.
    Visit this blog :
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by s0nic69 View Post
    No, my phone is with me overseas. I'm trying to connect to internet as if I was in US. I want to download Amazon MP3, which is not available outside the US. I bought all my music there and stored it in the cloud. Now I'm overseas and can't access it on my Sensation.
    BTW, WiFi calling totally works overseas! Like being at home!
