Results 1 to 2 of 2
- 12-06-2011, 07:19 PM
Thread Author #1
How many water sensors are there on the Sensation?
Hi I bought this faulty phone ... HTC sensation.. I'm looking behind the battery and the water sensor sticker is gone.. It's still under warranty but I don't want to send it in for repair and it turns out to be water damaged .. Their prices kill
. Even if I don't want to fix it theyll ccharge 35$ just for diagnosis .. So I'm just wondering if someone knows how to check if it's water damaged without the sticker behind the battery.. I just want to make sure it isn't before I send it in.. Any help is much appreciated! Thanks!
- 12-06-2011, 07:59 PM #2
Re: How many water sensors are there on the Sensation?
Should be a sticker on the battery and on the phone behind the back cover. Both should be white circle stickers with pink lines. If the lines are smeared/bleeding... you have water damage.
In your case... once the sticker is removed/gone, the warranty is automatically voided... sorry.
Reply
