05-21-2015 02:11 AM
44 12
tools
  1. basith123's Avatar
    if I open the recovery.img icon, it asking open with....
    there are no way to exract....
    Plss help me to run adb............
    12-24-2012 10:18 PM
  2. mooneygmh's Avatar
    What if you are not rooted and you accidently wiped your boot image ? I wiped my data , cache, etc , without making a backup and now my phone is stuck on the dre beats when I try to start it , what should I do ?
    01-03-2013 11:07 AM
  3. zkami79's Avatar
    You need to download this: Download HTCEvo4G/rooting/rootevo4ggingerbread.zip at DownloadAndroidROM.com I know its not for our phone, but it allows you to use ADB. Once it is downloaded, extract it and go to the folder in which is was extracted to. Hold SHIFT and right click in the folder and select "Open Command Window here" then you should be able to use the guide.
    Yes the recovery.img icon is white. Thats normal
    Dear Devgru82, I m also facing the similar problem with my HTC sensation XE with beats audio. After using the adb reboot or adb reboot bootloader command through above mentioned link, I am still not able to find a solution. On using these commands, it says, "Device not found". Is there any other solution?
    01-20-2013 01:53 PM
  4. zkami79's Avatar
    Dear all,
    I am also facing the similar problem. Has anyone the solution?
    01-20-2013 02:01 PM
  5. Devon Townsend's Avatar
    my htc sensation drop and won't turn back on, Only vibrate when i try to turn it on, Do i need a screen? whats the solution
    01-20-2013 06:56 PM
  6. Sarah Jane Shute's Avatar
    plz help me!!!!!!!!!!!!
    i no nothing about fone's but my htc sence has stopped charging and no orange light either, iv tryed to down loads things on this page but is not working, is there anyone that can help and explain how i sort it out?????
    01-22-2013 07:20 AM
  7. Gina3512's Avatar
    I read your solution which is to run the command adb reboot. Maybe I'm just stupid, but PLEASE tell me how you can run ANYTHING when there is absolutely NO power on your phone whatsoever?
    02-24-2013 08:58 AM
  8. Angelic King's Avatar
    i just replaced the lcd and digitilizer in mine htc sensation and mine only vibrates when press power did you ever find a solution my screen dont light up or nothing i really need it fixed i know the phone is on after i hit the power button but it seems like theres no power to the screen
    02-27-2013 10:32 AM
  9. Thomas McCafferty's Avatar
    My htc sense just turns on and goes to the boot thing and then no matter what it comes up a white schreen says htc sence and is on that until it dies, every time what do i do?
    03-16-2013 02:02 PM
  10. superjep's Avatar
    I already donwloaded the file on the link and renamed it to recovery.img-
    next step on your instruction is to plug the unit and run the adb reboot/ adb reboot bootloader- it responded :" windows cannot find adb" tried running it thru cmd.exe and the response is "adb is not recognized as an internal or external command.
    as per RANCID88- i also tried DL the SDK though im not familiar on how to use it.
    Help please.
    Thanks...
    Is your phone rooted? You can try these step to see if you can get it working:
    Try this:
    Recovery IMG: http://api.viglink.com/api/click?for...13251045745723
    My Phone Died and i can't turn it back on!!! help!!
    1. Download the recovery i have posted above. Once downloaded rename to remove the name of the recovery until its just named recovery.img.
    2. Plug your device to a computer and run the command
    adb reboot
    or
    if your device doesn't turn on, then simply pull the battery, put it back in, then redo the steps.
    3. Once your phone does power on from one of those commands, reboot into android OS and put the recovery on the root of your sdcard.
    4.Boot into bootloader while plugged into the computer and run the following command
    fastboot flash recovery recovery.img
    Then the problem is fixed! I'm very sorry for the inconvenience, but thats the fix.
    Take from this thread on XDA: HTC Sensation General FAQ's. New to this device? Read here! UPDATED 8/3/11 - xda-developers
    05-05-2013 10:24 AM
  11. superjep's Avatar
    DLoaded Download HTCEvo4G/rooting/rootevo4ggingerbread.zip at DownloadAndroidROM.com- @ command window- error device not found
    whats the next step please...
    thanks...
    - - - Updated - - -
    thanks...
    05-05-2013 10:44 AM
  12. bjeyalakshmi's Avatar
    Im having the same problem ,tried replacing the battery .The phone doesnt turn on or the led for charging blink
    with the phone not turning on ,not sure how to download the .img file
    09-10-2013 01:08 PM
  13. pinkiepony's Avatar
    Same problem here. It used to be stuck in a boot loop, but now it's just not even turning on. If I wiggle the power cord, sometimes it will light up a little. It was lighting up and working this morning. Now it's not even responding to anything.
    10-08-2013 09:49 AM
  14. hithere111's Avatar
    how come when i download the recovery.img it says file is corrupted?
    12-24-2013 03:27 PM
  15. Kai Vj's Avatar
    i m havng t-mobies htc sensation 4g....my phone is not tutng on...it just shows a black light nd turns off...while i try 2 turn it on...when i put it to charge it shows red led light nd after 5 mnts it shows red nd green light...continously blinkg...can any one help to recovery my phine
    01-12-2014 05:20 AM
  16. rafael1369's Avatar
    hiI
    I did that but the command shows that error:device not found
    01-15-2014 11:26 AM
  17. lau-fung's Avatar
    hi, i did something it may be crazy, but its work.
    I was doing all steps that its written up, and then i realize my phone is hot, so i put it in frizzier after 30 min (cover it with plastic bag to protect it from water) i connect it with charge and Wala its work
    try it
    07-01-2014 06:35 PM
  18. karanbir Singh Batth's Avatar
    i have downloaded this link bt in my lapi it shows the cd burner software when i open it
    05-20-2015 10:34 PM
  19. karanbir Singh Batth's Avatar
    plzz help me , nothing is hpng with my phone
    05-21-2015 02:11 AM
44 12
