05-21-2015 02:11 AM
44 12
tools
  1. FloridaFlorida727's Avatar
    Just out of no where my sensation stopped powering on and doesn't display the led light when charging either. It does not have water damage and wasn't dropped or anything. This just happened out of no where. Does anyone know what I should do or anyone else have this problem?
    Ramon5281964 likes this.
    12-31-2011 02:32 AM
  2. devgru82's Avatar
    Is your phone rooted? You can try these step to see if you can get it working:
    Try this:
    Recovery IMG: http://api.viglink.com/api/click?for...13251045745723
    My Phone Died and i can't turn it back on!!! help!!
    1. Download the recovery i have posted above. Once downloaded rename to remove the name of the recovery until its just named recovery.img.
    2. Plug your device to a computer and run the command
    adb reboot
    or
    adb reboot bootloader
    if your device doesn't turn on, then simply pull the battery, put it back in, then redo the steps.
    3. Once your phone does power on from one of those commands, reboot into android OS and put the recovery on the root of your sdcard.
    4.Boot into bootloader while plugged into the computer and run the following command
    fastboot flash recovery recovery.img
    Then the problem is fixed! I'm very sorry for the inconvenience, but thats the fix.
    Take from this thread on XDA: HTC Sensation General FAQ's. New to this device? Read here! UPDATED 8/3/11 - xda-developers
    12-31-2011 10:06 AM
  3. FloridaFlorida727's Avatar
    Yes I have tried this and keep gettting an error on the command center saying "adb reboot is not a recognized internal or external command"
    Am I suppose to be running this from the command center on my computer like when you go to start and search and type in command?
    Also is the recovery.img icon suppose to just be white and not open?
    12-31-2011 11:28 AM
  4. legendary1022's Avatar
    Are you in the folder in which ADB is located on your computer?
    Sent from my MIUI.us Sensation 4G using Tapatalk
    12-31-2011 04:58 PM
  5. devgru82's Avatar
    You need to download this: Download HTCEvo4G/rooting/rootevo4ggingerbread.zip at DownloadAndroidROM.com I know its not for our phone, but it allows you to use ADB. Once it is downloaded, extract it and go to the folder in which is was extracted to. Hold SHIFT and right click in the folder and select "Open Command Window here" then you should be able to use the guide.
    Yes the recovery.img icon is white. Thats normal
    12-31-2011 05:24 PM
  6. jline1's Avatar
    i know that this is old but my sensation wont power on now ive got the adb however when i type the command it says error device not found.
    01-28-2012 12:10 AM
  7. EAW789's Avatar
    please someone help i have the exact same problem.
    no light when charging, wont turn on and the command gives "error device not found"
    03-13-2012 08:45 AM
  8. EAW789's Avatar
    the battery prongs on my phone were down so i pulled them up and now it is working fine
    03-13-2012 08:55 AM
  9. pollito12's Avatar
    i have a t-mobile htc with htc sense and the led light wont turn on its really hard to c. can anyone help me
    03-25-2012 06:23 PM
  10. buzz2020's Avatar
    Has anyone found a soultion to this problem. I have the same problem.
    I rooted my HTC to revolution_hd ice cream sandwich and the phone seem to be working fine. then it started to power off randomly but would restart.
    Now its power off and will not restart and it is not charging either. No LED
    Things I have tried -
    New Battery - No difference
    Jump starting
    ADB Reboot - get the "No device found" error message.
    Any suggestions would be great
    05-02-2012 06:31 AM
  11. Rancid88's Avatar
    buzz, are you in the adb directory?, if you are can you get the phone into recovery at all? if so try to kill the server and restart it, maybe it will read the phone
    05-03-2012 07:23 AM
  12. buzz2020's Avatar
    I have to run the Adb from command prompt
    The computer does not regonize the phone is plugged in
    05-03-2012 07:40 AM
  13. buzz2020's Avatar
    The phone is not responding to anything.
    05-03-2012 07:41 AM
  14. Rancid88's Avatar
    give this a look at i hope it helps
    http://forum.xda-developers.com/show....php?t=1522351
    05-03-2012 08:02 AM
  15. zeanixbabz's Avatar
    05-09-2012 12:01 PM
  16. jaida draper's Avatar
    I tried every download and did every direction given and still nothing worked.
    06-08-2012 05:50 PM
  17. rikuno's Avatar
    My galaxy S wont trun on it keeps doing that triple vibrate like if its trying to force close something and when it gets on all i see is a black screen and it keeps triple vibrateing HELP
    06-12-2012 12:08 PM
  18. marco103's Avatar
    my phone wont come on. What do i do ?
    Ramon5281964 and leroy1993 like this.
    07-01-2012 03:01 PM
  19. rustypop's Avatar
    helppppppppppp
    07-04-2012 03:12 PM
  20. ehalanis's Avatar
    Hello. my HTC Sensation 4G has the MIUI but I tried to install the original HTC Sensation, and know when the phone turn show the MIUI.US screen and does not continue ... I want to reinstal the original software, what I have to do ?
    08-03-2012 07:41 PM
  21. Rancid88's Avatar
    You all have to go and download the SDK and then The RUU files from XDA and simply follow the instructions and you should have your phone back up and running, if you continue to get the Device not found error you may need to make sure you have htc sync installed because you need the drivers
    08-03-2012 08:59 PM
  22. ISH3000's Avatar
    how do you use / extract the "recovery.img" .. i dnt get it, its a white icon with CD pic.. i dnt nothing about this and i am stuck after the download part... what should i do?
    Ramon5281964 and Wawa Kings like this.
    08-14-2012 05:44 PM
  23. maxytetsu's Avatar
    I have a htc sensation xe, he restarted the update and does not turn over, so get a flashing light when connected to pc or charger. I need some information on doing it at least turn on the mobo bootloader download helllllllp me ......
    ---------- Post Merged at 10:18 PM ---------- Previous Post was at 10:17 PM ----------
    Tenho um htc sensation xe, na atualizao ele reiniciou e no liga mais, so fica com uma luz piscando quando conecta no pc ou no carregador. Preciso de alguma informao em faze-lo ligar pelo menos no mobo download o bootloader......me helllllllp
    10-01-2012 09:18 PM
  24. Kendra Nolden's Avatar
    I'm having that same problem, but I went to t mobile today and they told me it was cause the circuits in my prongs make be out of whack. I love HTC, and the sensation is a great phone.
    12-03-2012 08:02 PM
  25. Simon Mccullagh's Avatar
    after reading all posts i hardly touched battery prongs tried battery there was a little spark and phone came on
    12-17-2012 05:01 PM
44 12
