Page 2 of 2 FirstFirst 12
Results 26 to 36 of 36
Like Tree1Likes
  1. #26
    Default Re: My HTC Sensation won't power on or show led or anything,
    if I open the recovery.img icon, it asking open with....
    there are no way to exract....
    Plss help me to run adb............
  2. #27
    What if you are not rooted and you accidently wiped your boot image ? I wiped my data , cache, etc , without making a backup and now my phone is stuck on the dre beats when I try to start it , what should I do ?
  3. #28
    Quote Originally Posted by devgru82 View Post
    You need to download this: I know its not for our phone, but it allows you to use ADB. Once it is downloaded, extract it and go to the folder in which is was extracted to. Hold SHIFT and right click in the folder and select "Open Command Window here" then you should be able to use the guide.
    Yes the recovery.img icon is white. Thats normal
    Dear Devgru82, I m also facing the similar problem with my HTC sensation XE with beats audio. After using the adb reboot or adb reboot bootloader command through above mentioned link, I am still not able to find a solution. On using these commands, it says, "Device not found". Is there any other solution?
  4. #29
    Dear all,
    I am also facing the similar problem. Has anyone the solution?
  5. #30
    my htc sensation drop and won't turn back on, Only vibrate when i try to turn it on, Do i need a screen? whats the solution
  6. #31
    plz help me!!!!!!!!!!!!
    i no nothing about fone's but my htc sence has stopped charging and no orange light either, iv tryed to down loads things on this page but is not working, is there anyone that can help and explain how i sort it out?????
  7. #32
    I read your solution which is to run the command adb reboot. Maybe I'm just stupid, but PLEASE tell me how you can run ANYTHING when there is absolutely NO power on your phone whatsoever?
  8. #33
    i just replaced the lcd and digitilizer in mine htc sensation and mine only vibrates when press power did you ever find a solution my screen dont light up or nothing i really need it fixed i know the phone is on after i hit the power button but it seems like theres no power to the screen
  9. #34
    My htc sense just turns on and goes to the boot thing and then no matter what it comes up a white schreen says htc sence and is on that until it dies, every time what do i do?
  10. #35
    I already donwloaded the file on the link and renamed it to recovery.img-
    next step on your instruction is to plug the unit and run the adb reboot/ adb reboot bootloader- it responded :" windows cannot find adb" tried running it thru cmd.exe and the response is "adb is not recognized as an internal or external command.
    as per RANCID88- i also tried DL the SDK though im not familiar on how to use it.
    Help please.
    Thanks...
    Is your phone rooted? You can try these step to see if you can get it working:
    Try this:
    Recovery IMG:
    My Phone Died and i can't turn it back on!!! help!!
    1. Download the recovery i have posted above. Once downloaded rename to remove the name of the recovery until its just named recovery.img.
    2. Plug your device to a computer and run the command
    adb reboot
    or
    if your device doesn't turn on, then simply pull the battery, put it back in, then redo the steps.
    3. Once your phone does power on from one of those commands, reboot into android OS and put the recovery on the root of your sdcard.
    4.Boot into bootloader while plugged into the computer and run the following command
    fastboot flash recovery recovery.img
    Then the problem is fixed! I'm very sorry for the inconvenience, but thats the fix.
    Take from this thread on XDA:
  11. #36
    DLoaded Download HTCEvo4G/rooting/rootevo4ggingerbread.zip at DownloadAndroidROM.com- @ command window- error device not found
    whats the next step please...
    thanks...
    - - - Updated - - -
    thanks...
    Quote Originally Posted by zkami79 View Post
