- 12-31-2011, 02:32 AM
Thread Author #1
My HTC Sensation won't power on or show led or anything,
Just out of no where my sensation stopped powering on and doesn't display the led light when charging either. It does not have water damage and wasn't dropped or anything. This just happened out of no where. Does anyone know what I should do or anyone else have this problem?
Thanked by: - 12-31-2011, 10:06 AM #2
- 12-31-2011, 11:28 AM
Thread Author #3
Re: My HTC Sensation won't power on or show led or anything,
Yes I have tried this and keep gettting an error on the command center saying "adb reboot is not a recognized internal or external command"
Am I suppose to be running this from the command center on my computer like when you go to start and search and type in command?
Also is the recovery.img icon suppose to just be white and not open?Thanked by: - 12-31-2011, 04:58 PM #4
Are you in the folder in which ADB is located on your computer?
Sent from my MIUI.us Sensation 4G using TapatalkThanked by: - 12-31-2011, 05:24 PM #5
You need to download this: I know its not for our phone, but it allows you to use ADB. Once it is downloaded, extract it and go to the folder in which is was extracted to. Hold SHIFT and right click in the folder and select "Open Command Window here" then you should be able to use the guide.
Yes the recovery.img icon is white. Thats normalThanked by: - 01-28-2012, 12:10 AM #6
i know that this is old but my sensation wont power on now ive got the adb however when i type the command it says error device not found.
Thanked by: - 03-13-2012, 08:45 AM #7
please someone help i have the exact same problem.
no light when charging, wont turn on and the command gives "error device not found"Thanked by: - 03-13-2012, 08:55 AM #8
the battery prongs on my phone were down so i pulled them up and now it is working fine
Thanked by: - 03-25-2012, 06:23 PM #9
i have a t-mobile htc with htc sense and the led light wont turn on its really hard to c. can anyone help me
Thanked by: - 05-02-2012, 06:31 AM #10
Has anyone found a soultion to this problem. I have the same problem.
I rooted my HTC to revolution_hd ice cream sandwich and the phone seem to be working fine. then it started to power off randomly but would restart.
Now its power off and will not restart and it is not charging either. No LED
Things I have tried -
New Battery - No difference
Jump starting
ADB Reboot - get the "No device found" error message.
Any suggestions would be greatThanked by: - 05-03-2012, 07:23 AM #11
buzz, are you in the adb directory?, if you are can you get the phone into recovery at all? if so try to kill the server and restart it, maybe it will read the phone
Thanked by: - 05-03-2012, 07:40 AM #12
I have to run the Adb from command prompt
The computer does not regonize the phone is plugged inThanked by: - 05-03-2012, 07:41 AM #13
The phone is not responding to anything.
Thanked by: - 05-03-2012, 08:02 AM #14Thanked by:
- 05-09-2012, 12:01 PM #15
Thanked by: - 06-08-2012, 05:50 PM #16
I tried every download and did every direction given and still nothing worked.
Thanked by: - 06-12-2012, 12:08 PM #17
My galaxy S wont trun on it keeps doing that triple vibrate like if its trying to force close something and when it gets on all i see is a black screen and it keeps triple vibrateing HELP
Thanked by: - 07-01-2012, 03:01 PM #18
my phone wont come on. What do i do ?
Thanked by: - 07-04-2012, 03:12 PM #19
helppppppppppp
Thanked by: - 08-03-2012, 07:41 PM #20
Hello. my HTC Sensation 4G has the MIUI but I tried to install the original HTC Sensation, and know when the phone turn show the MIUI.US screen and does not continue ... I want to reinstal the original software, what I have to do ?
Thanked by: - 08-03-2012, 08:59 PM #21
You all have to go and download the SDK and then The RUU files from XDA and simply follow the instructions and you should have your phone back up and running, if you continue to get the Device not found error you may need to make sure you have htc sync installed because you need the drivers
Thanked by: - 08-14-2012, 05:44 PM #22
how do you use / extract the "recovery.img" .. i dnt get it, its a white icon with CD pic.. i dnt nothing about this and i am stuck after the download part... what should i do?
Thanked by: - 10-01-2012, 09:18 PM #23
I have a htc sensation xe, he restarted the update and does not turn over, so get a flashing light when connected to pc or charger. I need some information on doing it at least turn on the mobo bootloader download helllllllp me ......
---------- Post Merged at 10:18 PM ---------- Previous Post was at 10:17 PM ----------
Tenho um htc sensation xe, na atualização ele reiniciou e não liga mais, so fica com uma luz piscando quando conecta no pc ou no carregador. Preciso de alguma informação em faze-lo ligar pelo menos no mobo download o bootloader......me helllllllp - 12-03-2012, 08:02 PM #24
- 12-17-2012, 05:01 PM #25
Reply
