1. Nonelle's Avatar
    This is literally what my battery life is like.
    I charge it for a while (until it's 100%) and then I go use my phone to do something like play a simple game and bam. It turns off on me and when I turn it back on it's 2% and it was only a minute. It was fine when I first got it... Was it because I downloaded too many apps? I deleted almost all of them so shouldn't it be fine now? I've had this phone since mid-May. Yes I put the screen brightness on auto.
    08-19-2013 07:36 PM
  2. B. Diddy's Avatar
    Are you able to try a different battery?
    Nonelle likes this.
    08-19-2013 07:40 PM
  3. Nonelle's Avatar
    I'm a young dumb teen. I don't really want my parent's to know about the problem (we're not that rich.) Also, I've heard that replacement batteries cost a lot so I'm afraid to ask.
    08-19-2013 07:46 PM
  4. Travo79's Avatar
    If you or your parents got your phone from a carrier then you should take it back and show them that battery screenshot. That is in no way normal and would most definitely get you a new (free) battery or a phone replacement.
    .....Unless of course you've damaged your phone or battery in some way.
    Nonelle likes this.
    08-19-2013 07:51 PM
  5. Nonelle's Avatar
    I don't recall damaging my phone in any way but thanks I'll try.
    08-19-2013 07:59 PM
  6. B. Diddy's Avatar
    $7 including shipping:
    Amazon.com: HTC Sensation 4G 1520 mAh Original Standard Battery: Cell Phones & Accessories
    Nonelle likes this.
    08-19-2013 08:29 PM
  7. Nonelle's Avatar
    Wow, I thought that they cost over a hundred dollars. I guess my information was wrong. I'll try it out, thanks!
    08-19-2013 08:30 PM
  8. B. Diddy's Avatar
    I suggest shopping around a bit for a replacement battery. Just go to Amazon and search for "HTC Sensation battery," or do a Google Shopping Search for it. The one I posted is probably fine (and for that price, there's not much to lose), but I did see a few 1 star reviews from people who said that what they got didn't work very well (while there were also 5 star reviews saying it worked perfectly).
    Here's a video showing how to remove and replace the battery:
    Nonelle likes this.
    08-19-2013 08:35 PM
  9. Nonelle's Avatar
    Thank you very much! You were very helpful!
    B. Diddy likes this.
    08-19-2013 08:43 PM
  1. We already have problems
    By tdizzel in forum Moto X (2013)
    Last Post: 08-21-2013, 11:31 AM
  2. Nexus 7 with Sky email problem
    By Solum in forum Introductions
    Last Post: 08-21-2013, 08:25 AM
  3. Sd card problem
    By Vadendil in forum Android 4.0 Ice Cream Sandwich
    Last Post: 08-20-2013, 12:02 AM
  4. Wifi Problem
    By kv_kalyan1 in forum Samsung Galaxy S3
    Last Post: 08-19-2013, 12:50 PM
  5. color fades problem on chrome and wifi bar
    By mikemike162012 in forum Google Nexus 7 Tablet (2013)
    Last Post: 08-19-2013, 12:39 PM
