Results 1 to 21 of 21
Like Tree2Likes
  • 1 Post By Eric Mazariegos
  • 1 Post By Jeremiah Bonds
    Jeremiah Bonds's Avatar
    Posts
    Global Posts
    1,119 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default T-Mobile LG G2: Battery Drain w/ KitKat
    Those who have successfully loaded kit kat, have you guys noticed a battery drain?
    My battery used to last me 13-18 hours easy.. depending on usage, some times even 23ish hours.
    but now with Kit Kat I'm lucky if I get 8 hours.. has anyone noticed this change?
  2. #2
    bc4393's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Battery Drain w/ Kit Kat
    Mine got horrendous after the update until I ran the app update program (I think its LG's) then rebooted when everything was up to date.
    Posts
    Global Posts
    1,119 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    All my apps in the LG app update thing are up to date.. I don't want to factory reset this phone. I'm kind of bummed.
  4. #4
    shugga82's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: T-Mobile LG G2: Battery Drain w/ Kit Kat
    I'm now starting to see the drain the phone was better on jellybean
    Posted from my T-Mobile LG G2 via Android Central App
  5. #5
    HIMAN1998's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Hmm, odd. I have better battery life under Kit Kat. I normally could only do like 15 hours of very heavy usage, but I'm at 48% with that same usage, after 13 hours. If it might make a difference, I also installed Nova Launcher because I love the look and feel, and with 4.4 the softkeys have the transparent background like the stock launcher.
  6. #6
    shugga82's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Idk but I don't have anything installed like Facebook that would pull data. even the weather widget updates but doesn't show correct location. I keep getting an error message when trying to update manully.I might just do a factory reset
    Posts
    Global Posts
    1,119 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I don't know.. you must be lucky.. I tried the new and improved auto brightness.. and i tried the screen on dim.. It just doesn't last as long for me anymore.. I'm kind of bummed.. The phone is a lot more smooth, but at the expense of my battery only living half as much.
  8. #8
    raysgrumpy's Avatar
    Posts
    Global Posts
    437 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    My wife absolutely hates the update. It is killing her battery. We used to joke about how the battery in her G2 crushed my Nexus 5. With the change in the location settings, she can't get a GPS lock inside, at all, anymore. We both play Ingress and she can't use it in the house anymore, always has to go outside to get a lock. She's tried playing with all the settings. I guess we're going to try a factory reset. She's pissed! haha
  9. #9
    shugga82's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by raysgrumpy View Post
    You're right the GPS changed the weather widget gives an error msg...wish I hadn't updated. The battery drain is bad
  10. Thread Author  Thread Author    #10
    Posts
    Global Posts
    1,119 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I'm doing a factory reset to see if it will fix anything.. Also, it makes the phone seem newer
  11. #11
    Eric Mazariegos's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    You guys now that KitKat institues new location settings right? If you're using GPS at all, you're using the highest level locatioin setting, which drains the battery the most. You should definitely only use that setting at times which you really need GPS access. Set your location setting to "battery saving mode," which only uses the wifi and mobile data signals to determine your location.
    pantlesspenguin likes this.
  12. #12
    shugga82's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Eric Mazariegos View Post
    I discovered that this morning after I did a factory reset the highest level should be used for navigation anything else set to battery saving. I'll see how the battery is now
  13. #13
    scmurphy13's Avatar
    Posts
    Global Posts
    315 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Weird. My battery life has been incredible. Been jumping back and forth between my G2 and my Note 3. Both on 4.4.2. G2 kills the Note 3. Only thing that keeps me switching back to the Note 3 is the screen size...and the multi-window feature.
  14. Thread Author  Thread Author    #14
    Posts
    Global Posts
    1,119 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine automatically was set to battery saving.. I actually turned GPS off completely yesterday and it seems to last pretty well now. Battery saving mode didn't save battery much for me.. I also turned off the universal "ok google" setting for google now, where you can say that on any screen and Google Search will start up.
  15. #15
    pantlesspenguin's Avatar
    Posts
    Global Posts
    7,288 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I got tired of the battery drain post KitKat. I'm factory resetting now . Hopefully that'll help.
  16. Thread Author  Thread Author    #16
    Posts
    Global Posts
    1,119 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by pantlesspenguin View Post
    I did a factory reset.. didn't quite help.. The only thing that helps is having location off until I actually need it.,
  17. #17
    Posts
    Global Posts
    7,288 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by scmurphy13 View Post
    I hope the multi-window feature from the G Flex gets ported to the G2.
  18. #18
    mount.zed's Avatar
    Posts
    Global Posts
    171 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    my battery life is better, and I also seen better GPS performance. Mind you I am using a unlocked D802
  19. #19
    Matthew Hay's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: T-Mobile LG G2: Battery Drain w/ KitKat
    I have noticed my battery life is a lot shorter and my phone gets hot quickly as well. Never did this before kitkat
  20. Thread Author  Thread Author    #20
    Posts
    Global Posts
    1,119 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Greenify saved me
  21. #21
    RandelG's Avatar
    Posts
    Global Posts
    21 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Had this problem when I got the G2 back in March. I rebooted or rather did a factory reset and the problem was resolved.
  1. Note 3: My battery calibration history, for your reference
    By clevin in forum Samsung Galaxy Note 3
    Last Post: 06-26-2015, 04:11 PM
  2. Battery on new Galaxy Note 10.1 a disaster
    By Nychotxxx in forum Samsung Galaxy Note 10.1
    Last Post: 03-10-2014, 04:39 PM
  3. Nexus 7: Strange Battery Graph, wonder if it suggests problem?
    By Eaton Scrapple in forum Google Nexus 7 Tablet (2013)
    Last Post: 03-10-2014, 04:15 PM
  4. Galaxy Note 3: Batteries performing different?
    By Gadgetdude in forum Samsung Galaxy Note 3
    Last Post: 03-10-2014, 02:51 PM
  5. Phone signal and it's effect on battery life
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 03-10-2014, 11:18 AM
