Results 1 to 2 of 2
- 09-18-2011, 11:28 PM
Thread Author #1
Help! SuperBoot Soft Bricked My Phone
I tried to use the superboot method for 2.3.4 as I have in the past, and did it, but now my phone gets stuck on the Google screen with the unlock symbol. I can boot into Bootloader Mode, but I have to do a battery pull to get off the Google screen. I need help ASAP.
I have a Mac with Fastboot installed
I need to get fresh 2.3.4, no root
I have the stock recovery - 09-20-2011, 10:20 AM #2
Flash the stock ROM with Clockwork. You can find stock rooted ROMs on XDA. If that doesn't work you can flash back to stock with Odin.
Sent from my Google Nexus S
Reply
