WTH happened with double tap/zooming in in ICS?
big_time2
237
8
Haven't had a chance to use my Nexus S until today and I notice that zoom in/out icon in the browser is no longer there. That was great for zooming in because the text would auto adjust to fit the screen if I needed to zoom in/out?
Also double tap no longer auto adjusts to fit the screen. If I open a full size website and double tap to zoom in, the text is all over the phone, I have to slide left/right to read the text.
It's hard to believe that Google would get rid of this feature. Is this just my phone? I tried searching to see if there is any way to adjust it, maybe an additional setting that needs to be checked, but I couldn't figure it out.
Um, mine still wraps text. If you pinch to zoom in, you have to double-tap to wrap the text. I think the zoom buttons accomplished both tasks at the same time.
Try it, I assure you it still works. I'm using 4.0.3 (stock, not rooted or anything) on a T-mo Nexus S.
slackingfred
