1. ROB_M's Avatar
    Hi, I was wondering if it is possible to switch to T-Mobile with my Nexus S4G from Sprint. I see that they have much cheaper plans. If so, how should I go about doing this? Do I need to root to do it?
    Thanks in advance,
    Rob_M
    04-05-2012 02:36 PM
  2. BergerKing's Avatar
    A qualified no. Sprint is CDMA technology, T-Mobile is GSM. You would be best served by trading for a T-Mobile branded device.
    04-05-2012 03:34 PM
  3. font1975's Avatar
    Or trading for a GSM Nexus S
    04-05-2012 05:26 PM
  4. ROB_M's Avatar
    Thanks BergerKing. I appreciate the reply. I just got back from T-Mobile and they explained it to me about the technology. That sucks. I guess I might have to just get a new device if I switch over or consider different carriers.
    Rob_M
    04-05-2012 05:35 PM
  5. ROB_M's Avatar
    That's true also. Thanks for the idea font1975.
    Rob_M
    04-05-2012 05:39 PM
