Okay: took the same route home tonight and made the same call as in the first two reboots. Worked fine. I checked the network status at about the same place as the first reboot and noticed it was using Edge. It is possible that the signal type changed during the call.
For now, it looks like my factory reset has solved the problem, but I will continue to add stuff and try the same call each day.
Notable apps I haven't reinstalled yet are Skype and LauncherPro. I have the full list in app brain, I'll update this post with a link to that when I get home.
Sent from my Nexus S using Tapatalk
