Results 1 to 15 of 15
- 03-14-2011, 05:56 PM
Thread Author #1
nexus s not updating after unrooting!
so i needed to unroot my nexus because of warranty reasons, and i updated successfully to 2.3.2 but when i try to apply the 2.3.3 update my phone will not open it and install it. has this happened to someone else before? on the recovery it says
E: Error in /tmp/sideload/package.zip
(status 7)
installation aborted
I don't know if the radio in the phone is messed up or if i just forgot about something. i tried doing system check in's but those aren't working. i'm really pissed about this, and frustrated. Please help if you know a solution or heard of this happening before. - 03-14-2011, 08:42 PM #2
If this is for a return or factory repair, I wouldn't worry about it. My NS (still stock) has yet to receive the update notification, too.
All checkin does is check in to Google's servers. If the update isn't queued for your phone, you won't get it.
As to why the manual update is failing, I don't know. - 03-14-2011, 10:43 PM #3
Well try this, I am not sure if it will work but we will see. Plug your Nexus S into your computer and then look for files that you think could be stopping it from updating. Delete them or at least save them somewhere else on your computer (just in case) and then try to update manually. Tell me if this helps.
- 03-17-2011, 10:40 AM #4
- 03-18-2011, 12:55 AM
Thread Author #5
- 03-18-2011, 02:26 AM
Thread Author #6
- 03-18-2011, 02:57 PM
Thread Author #7
ok, 1stGenRex, i email the guy that posted those instructions, and emailed me back telling me that my radio version is totally different than the one he posted, he told me that my baseband version is "XXKB3". So this makes sense now, i knew it had something to do with the radio. I just had to dig a little deeper i guess.
**still doesn't work...** - 03-18-2011, 06:39 PM #8
- 03-19-2011, 04:07 PM
Thread Author #9
- 04-08-2011, 05:18 AM #10
- 04-08-2011, 11:56 AM
Thread Author #11
- 04-10-2011, 08:29 AM #12
- 04-10-2011, 02:02 PM
Thread Author #13
- 05-01-2011, 10:59 AM #14
- 05-01-2011, 06:51 PM
Thread Author #15
Reply
