Results 1 to 8 of 8
- 05-06-2011, 08:57 AM
Thread Author #1
Macbook Pro can not connect to Nexus S WiFi hotspot.
Hello everyone, I have a 13' Macbook Pro and for some reason I cant connect to nexus s(2.3.4) wifi hotspot. I have tried disabling and enabling encryption nothing works, macbook says "connection timeout". Also I have noticed that mac asks for WEP pass insted WPA2. Any ideas what it can be?
Thanks! - 05-06-2011, 12:06 PM #2
Thats weird, i have a MacBook, and have been using hotspot on 2.3.4 and it's working fine for me. maybe when you set hotspot on, there is other settings called "portable wifi hotspot settings" and in that tab click on configure wifi hotspot. Make sure the security is set on open, and also maybe change the name of the signal so your computer is seeing it as a different name. Hope this helps in any way!
- 05-06-2011, 12:54 PM
Thread Author #3
- 05-06-2011, 06:13 PM #4
- 05-07-2011, 08:07 AM
Thread Author #5
- 05-07-2011, 11:48 AM #6
- 01-25-2012, 08:38 AM #7
Re: Macbook Pro can not connect to Nexus S WiFi hotspot.
It seems to be a hit am miss type of issue. I have an iPad and it works fine. My MacBook Pro will connect but then is dropped after a couple of minutes. I have tried various things like firewall, opening up security, etc. Finally gave up and using EasyTether Pro with a USB connection. If I did not have my iPad, I would discontinue service. Verizon will not admit there is a problem even with all of the posting though out the internet of people having a problem. Of course they say it is an Apple hardware issue. One other little bit of information. This PC is dual boot within Windows 7. It also has the same problem.
- 01-26-2012, 08:19 AM #8
Try the option to connect to another network. This will give you the option to select the encryption method rather than let the mac autodetect it. Might just be the solution... Worked for me on some hotspots in the past, though myself have never had issues with tethering to my android phones, nexus or otherwise.
Sent from my ST18i using Tapatalk
Reply
