Results 1 to 3 of 3
    Ryan.Drais's Avatar
    Posts
    ROM
    Stock
    Default So I have a 1500Mah battery, but
    I need a new one, and its a 1440 mah battery. Are all Nexus S batteries innerswappable? The 1440Mah is also a Samsung battery that says its made for the Nexus S. Mind you I have the Rogers model from Canada, so I just wanted to check before I flop down money :P
  2. #2
    Baconator's Avatar
    AC Adviser
    Posts
    Global Posts
    1,015 Global Posts
    ROM
    Pure Google
    Default Re: So I have a 1500Mah battery, but
    Quote Originally Posted by Ryan.Drais View Post
    I think so. I think that if it says made for the Nexus S it will work just fine.
    Ryan.Drais's Avatar
    Posts
    ROM
    Stock
    Thank you for the reply. I just wanted to double check before I shipped out for a new battery that they are all innerswappable. Thanks Baconator!
