1. gammarayzzz's Avatar
    I rooted, got clockworkmod, and installed Cyanogenmod 7 and the phone wouldn't go past the loading screen with the Android guy on a skateboard. Well, I booted into recovery mode and tried to factory reset, wiped everything, and cleared everything off of my sd card, and I'm now stuck in fastboot mode. I tried downloading a custom recovery, but every one I download gives me a 404 error. I have Android ver 2.2.1, not sure what firmware I've got, but I really need help.
    09-26-2011 02:47 PM
  2. arhtard's Avatar
    sounds like a mess.
    i can only suggest heading over to xda forums and do some searching
    Android Development and Hacking - xda-developers
    i'm guessing you should get the lg flash tool and flash the firmware again.
    something like this: firmware download pc application and flash the file you download
    09-26-2011 02:51 PM
  3. arhtard's Avatar
    ahh found some directions to reflash firmware for the optimus one p500 - which is basically the same as our optimus t p509.
    this should get you going: How to flash firmware
    the program to flash your firmware is called KDZ updater apparently
    remember, when u flash original firmware - you will need to re-root your device
    good luck friend
    09-26-2011 02:54 PM
  4. kendixon69's Avatar
    i am a long past retired electronic engineer and just enjoying my years in retirment
    09-25-2012 06:40 PM
