1. gladesofsummer's Avatar
    I'm helping my friend try and figure out why his Optimus T won't hold a charge. Anyone have a similar issue that has found a solution besides it being a hardware issue because it shows its charging, but the battery level decreases while charging. Thanks.
    08-07-2012 12:42 AM
  2. Rayz321's Avatar
    His batter might just be dead, you could probably get a new one on ebay for just a few dollars
    08-16-2012 07:13 PM
