1. chad.jordan93's Avatar
    LG Optimus T - blue
    My phone is stuck in the emergency mode with the yellow screen.
    Ill take you through what happened,
    I wanted to update to 2.3.3, so i downloaded kdz updater and followed the tutorial on how to do so, I downloaded the ROM that i was told to download and I initiated XDA updater with the right type (3gqct) and phone mode (diag)--- right off the bat i got an error message on the program and the phone went to the emergency mode screen. I retried a good 5-7 times...nothing.
    I looked around and people said to flash back to original ROM (2.2.2) and i tried that with the right stuff selected(3gqct) and emergency instead of the "diag"...but nothing.
    I looked around and i have yet to find anything that can help, I cant hard reset it or any type of reset. the kdz program isnt working with any combo of steps...
    I'm lost please help! I just got this phone yesterday and thought i would be doing some good updating it. But now im back to my blackberry.
    and i can't doing anything to the phone through my computer without having the battery out... idk if that is something or not
    Here's the Log Report:
    [15:51:32:927] : =============================================
    [15:51:32:927] : Log is started on 01.10.2012, at 15:51:32:927,
    executable: C:\Users\Chad Kantlehner\Desktop\Android Crap\KDZ_FW_UPD_EN\KDZ_FW_UPD.exe (ProcID: 0x00000bac),
    compile time : Dec 8 2010 09:19:37
    [15:51:32:927] : Version :
    [15:51:32:937] : Get Usb Port
    [15:51:32:937] : rsi.strFriendlyName=LGE Android Platform USB Serial Port (COM3)
    [15:51:32:937] : FriendlyNameList[iii].szFriendlyName=LGE Android Platform USB Serial Port
    [15:51:32:937] : WM_COPYDATA ޽ 1 - COM3
    [15:51:32:937] : Port = COM3
    [15:51:32:957] : UNKNOWN : Req(12) -> Rsp(13)
    [15:51:32:967] : UNKNOWN : Req(12) -> Rsp(13)
    [15:51:32:977] : UNKNOWN : Req(12) -> Rsp(13)
    [15:51:32:977] : >> DIAG_STATUS_F FAILED
    [15:51:32:987] : >>Get Model Name [DIAG_VERNO_F]
    [15:51:32:997] : BAD CONN MODE : Req(0) -> Rsp(3)
    [15:51:33:007] : BAD CONN MODE : Req(0) -> Rsp(3)
    [15:51:33:017] : BAD CONN MODE : Req(0) -> Rsp(3)
    [15:51:33:027] : BAD CONN MODE : Req(0) -> Rsp(3)
    [15:51:33:037] : BAD CONN MODE : Req(0) -> Rsp(3)
    [15:51:33:047] : BAD CONN MODE : Req(0) -> Rsp(3)
    [15:51:33:047] : FAIL (No Phone)
    [15:51:33:047] : GetModelName() Operation Failed Check Diag CMD
    [15:51:33:047] : EMERGENCY Booting Mode
    [15:51:33:047] : >>Get Model Name in Emergency Mode [DLOAD_VERREQ_F]
    [15:51:33:057] : BS/P504/7DHADKA~1\AppData\Local\Temp\DZ
    [15:51:33:057] : WM_COPYDATA ޽ 0 - P504
    [15:51:33:067] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
    [15:51:33:067] : [ DLOAD ERROR ] : NAK_INVALID_LEN
    [15:51:33:077] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
    [15:51:33:077] : [ DLOAD ERROR ] : NAK_INVALID_LEN
    [15:51:33:087] : DLOAD_NAK_F reason_msb = 3, reason_lsb = 3
    [15:51:33:087] : [ DLOAD ERROR ] : NAK_INVALID_LEN
    [15:51:33:087] : NV Write Fail : NV ITEM 9028(9028)
    [15:51:33:187] : >> GET DLOAD COMM MODE
    [15:51:33:197] : [GetCommMode] Communication mode : 2
    [15:51:33:197] : Pre Nand Download
    [15:51:33:197] : >>Set Trusted Mode [DLOAD_NAND_SEC_MODE] sec_mode = 1 (1=trusted 0=NonTrusted)
    [15:51:33:197] : WM_COPYDATA ޽ 3 - TRUSTED MODE
    [15:51:33:207] : [COM3] >>NandFlashInitWithFile(PARTITION TBL)
    [15:51:33:207] : WM_COPYDATA ޽ 3 - INIT PARTITION TBL
    [15:51:33:227] : ޽ TYPE_WPARAM_WRITE_TO_SDRAM 3
    [15:51:33:227] : [COM14] ޽ TYPE_WPARAM_WRITE_AMSS 15
    [15:51:33:227] : [COM3] >>NandFlashInitWithFile(AMSS MODEM HEADER)
    [15:51:33:257] : WM_COPYDATA ޽ 3 - INIT AMSS MODEM HEADER
    [15:51:33:267] : [COM14] >>Dl_AsyncWrite()
    [15:51:33:267] : >> AMSS FLASHING ...
    [15:51:33:267] : ޽ ProgreassiveBar Init wParam TYPE_WPARAM_PROGRESSIVE_POS=5 lParam(pos)=0 nResult=0
    [15:51:33:267] : Sending Pkt Seq : 0
    [15:51:33:267] : Sending Pkt Seq : 1
    [15:51:33:267] : Sending Pkt Seq : 2
    [15:51:33:267] : Sending Pkt Seq : 3
    [15:51:33:267] : Sending Pkt Seq : 4
    [15:51:33:267] : Sending Pkt Seq : 5
    [15:51:33:267] : Sending Pkt Seq : 6
    [15:51:33:267] : Sending Pkt Seq : 7
    [15:51:33:267] : Sending Pkt Seq : 8
    [15:51:33:267] : Sending Pkt Seq : 9
    [15:51:33:287] : Dl_AsyncWrite - ErrNo(45), Addr(0x00004800), NandErrNo(0x04)
    [15:51:33:287] : [COM14] ERROR Dl_AsyncWrite() TYPE_LPARAM_UPGRADE_ERROR_WRITE_TO_FLASH
    [15:51:33:287] : WM_COPYDATA ޽ 3 - Close Port
    [15:51:33:287] : Close Port<<
    [15:51:33:287] : TYPE_WPARAM_UPGRADE_ERROR
    [15:51:33:287] : ޽ - TYPE_WPARAM_UPGRADE_ERROR Error Code = 4008
    [15:51:33:367] : Log finished
    10-01-2012 10:19 PM
  1. Stuck on the emergency call screen
    By mcll in forum Other Sony Android Phones
    Last Post: 06-09-2012, 09:00 AM
  2. Tried rooting now my phone is stuck on the Google screen Help!
    By craigrn16 in forum Verizon Galaxy Nexus Rooting, ROM's, and Hack's
    Last Post: 05-25-2012, 05:14 AM
  3. Replies: 3
    Last Post: 12-15-2011, 03:41 PM
  4. TB stuck on Liquid Gingerbread start up screen. HELP!
    By Lionheart068 in forum Thunderbolt Rooting, ROMs, and Hacks
    Last Post: 11-21-2011, 01:26 PM
  5. Stuck on the Moto boot screen (Bats)
    By beloved1228 in forum Motorola Droid Rooting, ROMs and Hacks
    Last Post: 07-25-2010, 12:35 PM
