Results 1 to 5 of 5
    Default [ROM] CyanogenMod 10 for optimus T
    I downloaded and added the g apps file to get the market place and now i cant get the "Unfortunately google services framework has stopped" error. Anyway to fix this?
  2. #2
    Default Re: [ROM] CyanogenMod 10 for optimus T
    Are you using the right Google Apps?
    And this phone is mostly on XDA. I recommend searching for bugs there and posting.
  3. #3
    boblu's Avatar
    Posts
    ROM
    CM7
    I am having the same problem. I used the
    [ROM][4.1.1][CM10][UNOFFICIAL]LG Optimus One Family CM10[Sept. 9, 2012: Build 5] from xda forum, and the Google Apps Lightweight for ARMv6 provided in the same post.
    Sorry I don't have the posting right in the dev forum.
  4. #4
    Quote Originally Posted by boblu View Post
    Use the discussion thread under general over on CDS for this question.
    Swyped from my P509 on Tmobile.
    With Swype and Flash, why would anyone choose the iPhone?
  5. #5
    bill.weckel's Avatar
    Posts
    ROM
    JB 4.2.2
    There isn't enough free space on your system partition after installing the CM10 rom for GApps. You need to free up some space on your system partition after installing the rom but before flashing GApps. Hopefully you also did all of your wipes prior to flashing. There are countless posts on this issue over at XDA. There are two tools in the works, one by me and another by someone else, that will give the ability to edit the ROM from your PC prior to flashing it so as to have enough free space for a good clean installation of GApps.
    Device: LG Optimus T P509
    Rom: JB 4.1.2
    Kernel: CM10 ( built-in )
    My Tools for Android
    Android Flash Recovery -
    A Windows GUI front-end for fastboot to simplify flashing Android recovery partitions.
    OOne ROM Editor -
    A Windows utility for trimming ICS and JB ROMs for the LG Optimus One Device Family
    Thanked by:
    faheyd
  1. [ROM][JB][WIP] CyanogenMod 10 for LG-P505/506
    By Oathkeeper1212 in forum AT&T LG Phoenix/Thrive
    Last Post: 01-11-2013, 03:16 PM
  2. [WIP][ROM] CyanogenMod 9 for LG Optimus S (Yes, it's ICS!)
    By drewwalton19216801 in forum LG Optimus S Archived ROMs and Hacks
    Last Post: 12-05-2012, 05:04 PM
  3. Quattrimus ICS ROM now available for Optimus S!
    By BuggerZ in forum LG Optimus S Rooting, ROMs, and Hacks
    Last Post: 07-20-2012, 11:54 PM
  4. Stock, Unrooted Rom and Recovery for Optimus Q
    By michaelsj in forum Virgin Mobile Optimus Slider
    Last Post: 05-09-2012, 04:49 PM
  5. [ROM] CyanogenMod 7 for Hero CDMA :: V7.0.3 (6 May 2011)
    By srkmagnus in forum HTC Hero Rooting, ROMs, and Hacks
    Last Post: 09-05-2011, 10:57 AM
