Page 1 of 2 12 LastLast
Results 1 to 25 of 47
Like Tree2Likes
    drellisdee's Avatar
    ROM Developer
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Here is a recovery for you guys! Tested Working on xda by Joesph Mother
    Let ThundeRom for T commence.
    [Dead Link Removed]
    Please check md5 of 82deaeec44c9b6b7095efcfa31fee099 prior to flashing
    See my recovery section in opt s Here for description of features and I'll build a full release version soon with proper credits etc.
    Only thing I'll change is remove test naming fyi.
    To install extract the recovery.zip (linked above) and flash_image.zip (from opt s post) and copy those to the ROOT of sdcard.
    To flash recovery from root # shell do these commands. If install-recovery.sh doesn't exist on your phone just move to next step.
    Code:
    # mount -o remount,rw -t yaffs2 /dev/block/mtdblock1 /system
    # cat /sdcard/flash_image > /system/bin/flash_image
    # chmod 755 /system/bin/flash_image
    # mv /system/etc/install-recovery.sh /system/etc/install-recovery.sh.bak
    # mount -o remount,ro -t yaffs2 /dev/block/mtdblock1 /system
    # flash_image recovery /sdcard/recovery-RA-GNM-OPT-T-test.img
    # reboot recovery
    Also dont worry about the E:Bad boot Message. Bad boot message is due to a evil service lg uses that instant reboots out of recovery. Service is disabled in my recovery causing that message on lg vortex, opt one and t. They use a different kernel setup on optimus s so that one doesn't have it. Its completely fine.
    If you would like to back up your stock recovery you can do it via this command from a root shell PRIOR to flashing recovery
    Code:
    dd if=/dev/mtd/mtd2 of=/sdcard/recovery-dump-T.img bs=4096
    I'm not going to host one as I'm not trying to get in any potential trouble from hosting LG's binary. Feel free for someone else to host and mirror stock if you want to.
  2. #2
    KSmithInNY's Avatar
    AC Forums Android Developer
    Posts
    Global Posts
    3,808 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Bueller? Bueller? I see 125 views and no posts? SOMEONE has to have some feedback on this?
  3. #3
    Joeseph Mother's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    What's even worse is 150 views, probably means about 50 downloads, and 1 thanks, and that came from the guy who had already tested it. As for feedback, works great, flashing a zip works. Signature toggle works, automatically starts as enabled. Backup works, I don't have apps2sd to know if backup+ext works. Wipe works. Mount works. USB mount works twice, if you try to mount it a third time it'll show working on the phone but won't show on the computer, restart the phone and it'll work twice again. Partition SD works. Adb su in recovery works.
    tomhub389 likes this.
  4. #4
    wheremyarm's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Ok, I think I got this to work but... after reboot recovery my phone rebooted, got to a screen with a picture of an android coming out of a box, appeared to reboot again, and is now asking me to set the phone up for the first time. Did I miss something? It looks like I'm just going to have to go through another restore with Titanium Backup again.
    Oh here's what happened in shell:
    Code:
    /sdcard/flash_image: No such file or directory
    failed on '/system/etc/install-recovery.sh' - No such file or directory
    # reboot recovery
    reboot recovery
    C:\android-sdk-windows\tools>
  5. #5
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Looks like you did it right, but what came up with the android guy and the box is stock recovery, not the custom one.
  6. #6
    Turducken's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    mik_os CM7
    Default
    It looks like everything went smoothly for me. I received both error messages that drellisdee said were to be ignored -
    \install-recovery.sh doesn't exist
    E:Bad boot message
    I'm now at a screen that says Android System Recovery and looks identical to that posted in the Optimus S post.
    Everything seems to be working great!
    I have some pointers for the noobs who rooted with the z4 method (like me). First install the SDK and drivers as explained in the [How to] Root sticky and follow steps 1-3.
    Next Open a CMD window and type the following:
    cd c:\wherever-your-sdk-tools-folder-is (mine for example is C:\Program Files (x86)\Portable\Android\tools)
    Code:
    adb shell
    su
    *make sure your phone isn't locked or asleep when you reach the "su" command. Your phone will prompt you to allow superuser action. Do so.
    *Note for Vista/7 users with UAC enabled - Depending on where you installed the Android SDK you may have to open the CMD window as an Administrator (search "cmd", right click "Run as Administrator")
    At this point you should now see # and you can begin to follow drellisdee instructions at the top of the page.
    tremendazo likes this.
  7. #7
    Turducken's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    mik_os CM7
    Default
    @wheremyarm - It looks like you did it correctly. All I can think of is make sure when you copy and paste that you don't include any extra spaces.
  8. #8
    tomhub389's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re-flash stock recovery
    First off just wanna thank all you guys out there getting the Optimus dev community up and running, d-rizzle, kSmith, Beezy, J Mother... kinda sounds like an android rap group, we all appreciate your time and effort.
    Main question is how do we go about reflashing the stock recovery if need be?
    Just change the last line of code to the correct name?
    I'm trying to make time to learn ADB but until then I'm on the dangerous crash course of guess and check. Long story short, I had the recovery up and running great, then realized uninstalling things in titanium completely gets rid of them even after a factory reset, (or is it because I wiped too much in the recovery?). Next thing, I find the stock V10L_00.kdz file and tried to flash it using the KDZ Updater and ended up with a completely non-responsive phone that won't turn on or even connect to a computer. Is this because I needed the stock recovery on there to flash the kdz?
    Thanks again guys.
    Oh yea, I have a replacement Opt T on the way from Tmo with free 3 day shipping. Gotta love Tmobile
  9. #9
    Turducken's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    mik_os CM7
    Default
    Quote Originally Posted by tomhub389 View Post
    ...then realized uninstalling things in titanium completely gets rid of them even after a factory reset, (or is it because I wiped too much in the recovery?)
    I ran into the same problem. Find yourself a system dump and then follow the instructions here:
    How to reinstall system apps _as_ system apps. - Android Forums
    This worked for me.
  10. #10
    tomhub389's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Thanks, yea I wasn't sure if that would fix it or not. I was trying to no avail to just find the stock firmware and flash it but that didn't go to smooth. Just have to wait on the replacement to get here now. Then I'm gonna learn/practice ADB with my G1 before messing around with this guy again.
  11. #11
    Xzan's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    2.2
    Default
    I did exactly what it's said in the howto and it worked
    Thanks a lot for all your work !
  12. #12
    warranty.is.now.gone's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Worked like a charm, thanks to all the devs and testers.
  13. #13
    inkee's Avatar
    Posts
    Global Posts
    7 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    worked great. first time doing this kinda thing. got really scared when i got an error about how there was no more memory or something on the phone. but then i just retyped it and it worked.
  14. #14
    jsutton27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by inkee View Post
    I got the same memory error... the phone rebooted and is now stuck in the fastboot screen , what can i do to fix this?
  15. #15
    jsutton27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    im getting the same error in when trying to flash in fastboot...
  16. #16
    jsutton27's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    [QUOTE=jsutton27;466218]im getting the same error in when trying to flash in fastboot...[/QUOTE
    now im stuck in the lg screen... =(
  17. #17
    plohip's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I just had the same problem (stuck at fastboot, not because of this recovery).
    What I did was flash the recovery with fastboot.
    You need to have the fastboot executable in your tools folder of the SDK.
    Take the battery out and attempt to go into recovery.
    Plug the phone into the computer, at the command prompt on your computer type "fastboot flash recovery.img" or whatever the recovery image is named on your SDcard. Once its done, I was able to reboot into recovery and restore my nandroid backup.
    Hope this helps you guys.
  18. #18
    ichisamurai's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    any custom roms on the optimus T?
  19. #19
    vepachnh's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    [QUOTE=jsutton27;466282]
    Quote Originally Posted by jsutton27 View Post
    Me too. I'm afraid if I bricked my phone. after reboot recovery command, it rebooted and stays put at the LG logo. removed battery, tried getting into recovery mode (power + home + vol down). don't know what i am doing wrong and how to unbrick it. did you get to fix yours? help please.
  20. #20
    wildcat2083's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Is their anyway to get the stock recovery back, I.didnt.see the dd if/of command until I.flasjed the custom recovery
  21. #21
    milestide25's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default help?
    can somebody help me? i don't really understand how to do any of the shell commands or anything like that. if it can be explained, i can understand it. i've never done any of it before, but i catch on really quickly to most things technical.
  22. #22
    el.rafael's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Quote Originally Posted by milestide25 View Post
    Right click on my computer.
    Select properties, then select advanced system settings.
    In bottom of the new window, select Enviroment Variables.
    Under System Variables, select New.
    Under Variable Name: type "adb"
    Under Variable Value: type the address for the folder that contains the adb (Mine is C:\android\platform-tools)
    Once this is completed, make sure you have all those attached files already on the root of your SD card.
    In your phone, go to settings/application/development and enable Debugging!!
    Then open up Command console in your Windows 7 or xp by going to start menu and in search bar type CMD.
    Now from this point on you are just using this CMD (big black window) to instruct your computer to find the ADB and use it to install the custom recovery into your phone.
    Follow the list of commands on the front page exactly as written. It will take you several attempts and cups of coffee
    Good luck,
    Jorge
    70challenger likes this.
  23. #23
    Kodeen's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    After copying the files to my sd card, I didn't even use the computer. Just installed a terminal emulator app and ran the commands directly on the phone, worked great.
    Great work, drellisdee!
  24. #24
    quailallstar's Avatar
    Posts
    Global Posts
    401 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Hi guys I need your help please
    I bricked my LG Optimus T P509 and it is stuck on the LG splash screen. I also cant seem to get into recovery mode. I somehow got into this yellow screen that says EMERGENCY MODE!!!
    What do I do? I'm looking to somehow flash back to the stock T-mobile rom.
  25. #25
    mar11974's Avatar
    Posts
    Global Posts
    17 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Will using KDZ_FW_UPD with original V10L KDZ file restore the Factory Recovery and System even after installing the Custom Recovery (is factory recovery included in the V10L KDZ?)?
