I've had this phone since November when it came out but the max I've seen from speed tests in a supposedly 42mbps hspa+ area is ~7000kbps.. is that about the max I should expect?
I know im mixing mbps and kbps together but.. I do my speed tests in kbps and T-Mobile uses mbps. I know this device is 14.4 mbps according to many sites.. so is half of that.. i guess the best I can expect?
I did a speed test at a local mall with the HTC One S and on the first speed test immediately got 9000kbps.
