1. ja5219's Avatar
    I've had this phone since November when it came out but the max I've seen from speed tests in a supposedly 42mbps hspa+ area is ~7000kbps.. is that about the max I should expect?
    I know im mixing mbps and kbps together but.. I do my speed tests in kbps and T-Mobile uses mbps. I know this device is 14.4 mbps according to many sites.. so is half of that.. i guess the best I can expect?
    I did a speed test at a local mall with the HTC One S and on the first speed test immediately got 9000kbps.
    06-03-2012 10:10 PM
  2. Ertwyu's Avatar
    The minimum speed for true 4G phones is technically 14.4 mbps.. The max I've gotten is only 5900 kb/s down.
    06-04-2012 09:36 PM
  3. ghstrdr110's Avatar
    I have gotten a max of 9.7 mbps twice, once out in West Lafayette IN on Purdue campus and once in Indianapolis. I get between 5 and 8 mbps consistently around Lafayette and between 6 and 9 mbps in Indianapolis.
    06-10-2012 05:27 PM
