Hi Guys:
I recently bought this phone from Metro PCS without paying attention that only brings 2GB of memory (BTW I don't recommend this phone to anyone because of this issue, you can't even have the basic apps on this phone)
3 Times a day I have to be deleting pictures and clearing the cache to be able to access the photo gallery.
The main problem is with whatsapp that stores all pics on the phone internal memory and not on the external SD card , even though in settings I have chosen to store everything on the external SD card. It is really a PITA that this phone has so little internal memory
I took a screen capture of the "Storage" under settings and this is what I get:
As you can see the phone says I have 286MB of pictures and videos in the internal memory of the phone.
I have moved all the pics and videos to the external memory and the phone still says that.
I can't find those videos and pictures. I even plugged in the phone to the PC and I can't see them.
The PC reports I have almost 2GB in the phone but when I try to see the sub-folders only a few MB are shown in the explorer, which means there are a lot of files I can't see even on my PC.
If I could access to those 286MB and move them to the external SD card ,at least I would get some space in the phone so I can use it a little bit better.
Any advise?
Thanks
Any advise?
Thanks
