Results 1 to 21 of 21
Like Tree1Likes
  • 1 Post By mspace81
    Question T-Mobile Samsung Galaxy Note 3 - signal
    I live in a town with iffy signal. excellent in cars and outside. I'm really starting to notice that when I have 4g data my cell signal is crap. I can walk into a building with 4g with barely a bar of cellular but when it drops to edge data my bars go all the way to 4 or 5 bars. Is this common?
  2. #2
    ade_tobat's Avatar
    Posts
    Global Posts
    147 Global Posts
    ROM
    Jedi Master 2
    Default Re: T-Mobile Samsung Galaxy Note 3 - signal
    Yes it is.. I believe thisbis how it works when ur on E full bars then it'll change to 4g, when ur reach 4g full bars then it'll change to 4g lte vice versa
    Sent from my SM-N900T using Tapatalk
  3. #3
    Bars display how strong your data signal is... So weak 4g signal is low bars... Edge isn't weak in your area so goes to full.
    Sent from my T-Mobile Note 3 using AC Forums.
    Quote Originally Posted by Almeuit View Post
    I thought the bars display cellular strength not data strength
  5. #5
    Quote Originally Posted by Tyler Lietz View Post
    It changed in 4.1.
    It changed in 4.1.
    They should have just made a separate bar. Its confusing because the new system doesn't really help at all with finding data in a poor signal home. I spent a hour looking last night for a spot with stable 4g. Only one spot in the house I found was able to successfully do a speed test and that was in a basement. Tried everywhere upstairs. The bar system really sucks. I needed the hotspot cause my internet went down though my ping times really suck in my whole town. My lowest ping time is 192 with 95% of them 250 or higher. No matter if I'm in an excellent Coverage spot or not
  7. #7
    My signal is at one bar in the house(Lake County, Illinois) .. It took me a couple of hours just to download a movie.. Making and receiving calls, and sms texting is fine. Sending mms messages and anything that uses data isn't good.. Unlimited data doesn't mean anything to me if I can't use it.
    Sent from Peaches on my GN2 using Tapatalk 2
  8. #8
    Quote Originally Posted by Peaches36 View Post
    What service indicator do you have? If your on edge or 2g (G) then it'll let you send text and calls but will struggle with downloading and mms.
    How does the sensorly map look for your area? Do you know anyone that is getting better service with Tmobile in your area?
  9. #9
    Quote Originally Posted by jscholz22 View Post
    It says 4g and I only have one bar.. The map shows good coverage in my area.. I don't know anyone with t mobile in my area.
    Sent from my SM-N900T using Tapatalk 2
    Attached Thumbnails Attached Thumbnails T-Mobile Samsung Galaxy Note 3 - signal-uploadfromtaptalk1385566109714.jpg
  10. #10
    Typically if I have one bar of lte I can still pull 10mb download speeds still. Have you tried turning off lte and using hspa+ to see if that helps? I know it's a pain but there may be some tower upgrades going on.
  11. #11
    How do I turn off the lte?
  12. #12
    Settings -connections tab - more networks - mobile networks - network mode - select second from the top.
  13. #13
    Thank you for the info..
  14. #14
    Yeah looks like a weak LTE signal. Try forcing it to HSPA only and it could perform better.
  15. #15
    Tried it and it didn't work
  16. #16
    It changed in 4.1.
    I thought it was only on 4.3 and up??
    Sent from my T-Mobile LG Escape running 4.1.2 using Tapatalk 2 (Central n Ohio Austin IL)
  17. #17
    I just got Tmobile today and am having same problems with signal strength too. I had a sprint note 3, used the 14 day trial period and my speeds were only getting as high as 3.5 download speed, once it got to 7.01.
    Tried speedtest when I got tmobile and somewhat the same. 3.5 download but dropped to a .46 download twice. Now my connection says 4g only, no more 4g lte. Does tmobile throttle when you approach 2gb cuz I am closing in on that?
    It seems I get better data signal when I place the phone against a window. Tmobile rep said I am in between two towers but still bad signal. He said I should wait 24 hours until my ported phone number takes full effect (one rep called me and it went to my boost phone despite my number already ported over)
  18. #18
    Quote Originally Posted by willanaya View Post
    If u got the 70$unlimited then its no throttling but if u do got a limit then tmo doesn't throttle till after u hit the limit not before.
    Thanked by:
  19. #19
    I'm wondering if I should take my phone back and go with AT&T.. I'd rather pay more for the performance that I want.. Unlimited means nothing if I can't use it.. What makes it so bad is I'm in an area with good coverage..
  20. #20
    mspace81's Avatar
    Posts
    Global Posts
    71 Global Posts
    I say go with whatever service gives you the best service. There's no point making yourself frustrated and paying for something that you are not able to fully use. Try another carrier and see if it works better for you.
    Peaches36 likes this.
  21. #21
    If you can't figure out what's going on do what's best for you. I personally couldn't afford my usage on AT&T lol. :P
  1. Replies: 17
    Last Post: 02-22-2014, 04:02 PM
  2. Foxfi on a T-mobile S4
    By rsxtcy4me in forum T-Mobile Samsung Galaxy S4
    Last Post: 12-22-2013, 08:58 PM
  3. Samsung Galaxy Note 10.1 (2014) College Student considering note 10.1
    By ewgrosschris in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 12-14-2013, 03:34 PM
  4. N.O.V.A. 3 and Note 3 (International Exynos version)
    By SpookDroid in forum Samsung Galaxy Note 3
    Last Post: 11-11-2013, 07:38 AM
  5. Foxfi on a T-mobile S4
    By rsxtcy4me in forum Samsung Galaxy S4
    Last Post: 11-10-2013, 01:52 PM
B
