See if anyone else has issues with this.
1. make sure wifi is off on your phone
2. double tap home button to launch s voice.
3. say text someone in your contacts (john or Call Bill) one of these two commands. txt or call
4. You should get a message saying can't find network. or something like this.
This is the issue I have been having since day one.
no issues on WIFI
Won't work on Tmobile cell service on 4g LTE.
Please reply if you are seeing the same thing or even get it to work and verify what version of Svoice you have.
What I have done so far.
1. I went to the store and swapped out 3 phones now,
2. I have hours and hours of testing and very much think it's a S voice 11.2 issue.
3. I went to the store and tested the s3 that has version 10.1 and it works like is should.
4. I tested the S4 that has version 11.1 and it works like it should.
The Note 3 has 11.2 and this function listed above will not work on these two commands.
I am very aggravated with this because I got the Galaxy gear watch for Christmas and using svoice goes back to the watch and fails.
no issues on WIFI
