I am currently in Denmark, using the GN3.
I connected my phone to the wifi connection where I am living (in Denmark) and it was working fine for a day or two. Plenty of scanned connections on the list.Then all of a sudden, all the scanned connections were gone, I can only get like two now. Those aren't important, but just thought I should mention it. Anyway, the connection I am using is saved on my phone, but it says that it is not in range. I made the phone forget that connection, thinking that I could just find it again and reconnect, but no. The phone doesn't even register the connection.
My room is next to the room that was the router and the walls are paper thin.
I restarted the phone, I restarted the router and it kept saying the connection wasn't in range. SO, I turned the router and the phone off for a few minutes then turned them on and it worked. I was away for the weekend, got home, and now it won't connect again. Says it isn't in range.
This problem is getting really annoying. Please help me out.
