Results 1 to 5 of 5
    sonic1519's Avatar
    Posts
    Global Posts
    45 Global Posts
    Default Help for syncing my Note 3
    I have a Note3 and wondering the best way or app to sync my contacts and calendar.
    Both ways to and from my office pc. Here's where it gets strange. I use Outlook 2013
    on my business pc along with outlook.com web mail. When i enter contacts or calendar
    events from my pc they sync perfect to the Note3. If i try to do the same from my Note3
    nothing happens. All my contacts on my phone have the outlook icon next to them.
    Also i can not edit contacts from my phone when i choose a contact it shows all the info
    but it is grayed out. So i guess i'm looking for a easy 2 way syncing app or fix. Samsung Kies
    should never have been released. Sorry to ramble thanks for any help out there..........
  2. #2
    Default Re: Help for syncing my Note 3
    Hmmmm......let me see if I can get anyone to help to with this.
  3. #3
    Golfdriver97's Avatar
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Pure Nexus/Franco Kernel
    What app are you using for your calendar? If it is the Samsung one, that always defaults to My calendar for the app, not any other account you may have. You can change it, but as far as I know, only for that one entry.
    sonic1519's Avatar
    Posts
    Global Posts
    45 Global Posts
    Thanks for the reply. Only way i got it to sync both ways for contacts and calendars events.Was to set up my outlook.com email address
    up as a microsoft exchange activesync. Couldn't believe the guy at T-Mobile knew what he was doing. usually those guys are of little help at all.
  5. #5
    Posts
    Global Posts
    32,673 Global Posts
    Carrier
    Quote Originally Posted by sonic1519 View Post
    Glad you got it to work, and thanks for posting the solution. See you around the forums.
  1. One Max or Note 3
    By squirtlover in forum HTC One Max
    Last Post: 03-08-2014, 10:28 AM
  2. Codes for MX PLAYER
    By monicakm in forum Samsung Galaxy Note 10.1 (2014)
    Last Post: 02-02-2014, 05:32 PM
  3. Replies: 9
    Last Post: 01-29-2014, 12:24 AM
  4. I need help i deleted everything off my internal memory!!!!
    By bigsmokeldn OT in forum Samsung Galaxy S4 Google Edition
    Last Post: 01-27-2014, 08:50 PM
  5. Having serious trouble with quick glance/direct dial widget. Help please!
    By normallynefarious in forum Verizon Samsung Galaxy S4
    Last Post: 01-22-2014, 07:15 PM
