1. JoePR31's Avatar
    Has anyone else had issues with voice control for answering or rejecting incoming calls not working anymore after updating to KitKat? And yes, I do have the feature enabled in settings.
    Sent from my SM-N900T using AC Forums mobile app
    03-06-2014 03:16 PM
  2. Boomernj1991's Avatar
    The Voice Control To Answer Or Reject A Call Does Not Work If The Vibration Is On
    boudicca00 likes this.
    03-06-2014 08:49 PM
  3. RoarLions's Avatar
    Perfect! That fixed it! Hopefully there will be a patch, because I can't imagine what possible conflict there could be with vibration and voice command other the noise the vibration causes.
    03-09-2014 01:53 PM
  4. JoePR31's Avatar
    Wow...that's absolutely correct...but ridiculous that I can't have my phone on vibrate and answer it using voice commands at the same time.
    03-11-2014 12:21 AM
  1. Google Voice vs Siri
    By JF7FSU in forum Verizon Samsung Galaxy Note 3
    Last Post: 03-07-2014, 07:49 AM
  2. Play Store: Touchless Control Update
    By Ry in forum Motorola Droid MAXX
    Last Post: 03-07-2014, 06:36 AM
  3. Can't find Call Duration if not in contact list
    By barebonez in forum Sprint Galaxy S II Epic 4G Touch
    Last Post: 03-06-2014, 12:51 PM
  4. Play Store: Touchless Control Update
    By Ry in forum Motorola Droid Mini
    Last Post: 03-06-2014, 11:28 AM
  5. Play Store: Touchless Control Update
    By Ry in forum Motorola Droid Ultra
