T-Mobile Note 3: Voice controlled incoming call answer/reject stopped working
JoePR31
3
Has anyone else had issues with voice control for answering or rejecting incoming calls not working anymore after updating to KitKat? And yes, I do have the feature enabled in settings.
Sent from my SM-N900T using AC Forums mobile app
Re: Voice controlled incoming call answer/reject inop
The Voice Control To Answer Or Reject A Call Does Not Work If The Vibration Is On
Perfect! That fixed it! Hopefully there will be a patch, because I can't imagine what possible conflict there could be with vibration and voice command other the noise the vibration causes.
Wow...that's absolutely correct...but ridiculous that I can't have my phone on vibrate and answer it using voice commands at the same time.
slackingfred
