1. noteiii007's Avatar
    Is it just me or is the screen rotation feature lagging at least 7 seconds now vs before upgrade to kit kat?
    03-08-2014 09:52 PM
  2. Deke218's Avatar
    I'm experiencing the same.
    Sent from my Galaxy Note 3.
    03-10-2014 06:59 AM
  3. IslandGuy's Avatar
    Same here. Annoying!
    Sent from my SM-N900T using AC Forums mobile app
    03-10-2014 01:07 PM
  4. MizGarfield's Avatar
    My screen rotation stopped working at all! Terrible. This morning update to build XXENB4... still no joy :-((
    My Galaxy Note is with free sim, would that make a difference?
    I Googled this issue some more and found this:
    http://www.justaboutphones.com/samsu...ation-failure/
    I thought: that can't be true: I tried it and it worked! I am happy!
    03-10-2014 03:54 PM
  5. ingenious247's Avatar
    I had that problem initially after I performed the update, but I found that a factory reset solved all issues for me. Phone's running like a champ
    Sent from my SM-N900T using Tapatalk
    03-10-2014 11:09 PM
  6. RSILLE's Avatar
    Turn off auto rotate, turn off phone, take out battery and sim card, replace, then turn on phone, turn on auto rotate and now it will work fine.
    03-13-2014 06:37 AM
  7. Liur Kunzler's Avatar
    Didn't work for me
    03-26-2014 02:58 PM
  8. Deke218's Avatar
    Really? And that did what exactly?
    03-27-2014 03:06 PM
  9. andyfoo's Avatar
    Restarting the phone does the same for me. After some time, the problem returns.
    Anyone knows if this is a known bug/?
    03-28-2014 03:40 AM
  10. tzr mes's Avatar
    i found that turning off smart Rotation in smart screen option under control solve my problem . hope it will help some one
    05-04-2014 04:51 AM
  11. abarzua21's Avatar
    My screen lags too, shuts off on me, also my screen rotates when I rotate is set to off. Very annoying. I know its from kitkat update because before I update I was on 4.3 and my phone was perfect never had lags, shut offs
    Sent from my SM-N900 using AC Forums mobile app
    05-07-2014 04:47 AM
  12. Michaeljlacey's Avatar
    I've been grinding my teeth a little, waiting for my Note3 to autorotate, for a while.
    I tried the remove battery & sim thing without success.
    What has worked though is to turn off the smart screen stuff, auto scroll on head movement etc.
    Autorotate is now much quicker to start.
    05-09-2014 04:01 AM
  13. Claire Hillis's Avatar
    Screen rotation in Camera app was stuck in Landscape. Turning off Screen rotation, shutting down device, removing SIM and Batt, and restarting has seemed to work for now.
    06-16-2014 10:40 AM
  14. jmk1127's Avatar
    The rotation lacks if smart rotation is turned on(screen won't rotate I'd you're lying on side in bed etc...) . Go into settings and turn off smart rotation and problem solved.
    07-19-2014 08:17 PM
  1. 128gb microSDXC card works on the Note 3!
    By dpham00 in forum Samsung Galaxy Note 3
    Last Post: 02-17-2017, 08:02 AM
  2. Lost "navigate home" on Moto X with update to 4.4.2
    By Puzzlegal in forum Moto X (2013)
    Last Post: 12-19-2014, 09:48 AM
  3. AT&T LTE Note 8 will we see an update?
    By Steve R8 in forum Samsung Galaxy Note 8.0
    Last Post: 04-11-2014, 02:12 PM
  4. Multi window on my Galaxy S 4 Active doesn't work ...
    By jpinto in forum Samsung Galaxy S4 Active
    Last Post: 03-18-2014, 12:18 AM
  5. Note 3: couldn't charge after 4.4.2 update
    By Liar Xp in forum Samsung Galaxy Note 3
    Last Post: 03-09-2014, 01:37 PM
