1. Bu Nor's Avatar
    I Searched every forums & google for fix nothing found well some had solution but it doesn't pin point whats the problem. as android phone owner for long time i know one thing for sure is that the problem isn't with my ******* router so please stop telling people to fix your router or contact router manufacturer. its the problem with stock rom kikkat note 3- for god's sake please don't tell me to factory reset wipe that *** or w/e cache partition. i have done that thousand times, its just annoying while watching Netflix on my note 3 wifi disconnects video buffers and comes back on after few minutes then repeats
    03-27-2014 03:34 PM
  2. SebasCvdB's Avatar
    In the dialer put *#0011# a new menu will pop up, press the "menu" key (Left of home key) and select WiFi and turn Wifi power saving OFF...
    03-27-2014 03:43 PM
  3. anon8380037's Avatar
    I haven't found that helped in the past, as others have said, but I will give it a try again later now I have been on KK for 2 weeks. My main issue is with public wifi, so I accept it may work in the OP's case. Let's see over a few days.
    Via my Note 3 on AC.
    03-29-2014 09:45 AM
  1. kitkat sd card
    By William Mcnulty in forum AT&T Samsung Galaxy Note 3
    Last Post: 06-03-2014, 10:35 PM
  2. One Device (Tegra Note 7) Will Not Connect to Chromecast
    By Benton Trerise in forum Google Chromecast
    Last Post: 05-10-2014, 02:24 AM
  3. Xperia Z1: Major battery drain issue since updating to KitKat
    By Tanksta1 in forum Android 4.4 KitKat
    Last Post: 04-25-2014, 12:19 PM
  4. Any news on when Verizon Galaxy Note 2 will get KitKat OTA update?
    By CarrierPigeon in forum Verizon Galaxy Note 2
    Last Post: 03-27-2014, 07:35 PM
  5. Deleting Software Update Notification
    By BobR1908 in forum Samsung Galaxy Note 3
    Last Post: 03-27-2014, 03:56 PM
