Hello,
I'm assuming this is a type of app that you can enable/disable apps & services that run on your device?
Usually you can disable anything safely without permanent damage. Most that seems to happen in the event you disable something that is required to run is you will get a " FC " or forced close error/pop up window when doing so. If that happens then just re enable the app/service.
Granted when you try to disable certain apps especially system apps you will generally get a warning window saying it can affect the device and its performance.
