Results 1 to 3 of 3
    Marco Feijoo's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default android wall how to
    Hello there I am new I rooted my note 3 t-mobile I am using Android wall .does anyone using it can screen what to disable and what to left open on black list , I don't wanna unable anything that cause problems to my phone performance thanks in advance
  2. #2
    Paul627g's Avatar
    Posts
    Global Posts
    17,762 Global Posts
    Mentioned
    1 Post(s)
    Tagged
    0 Thread(s)
    Default Re: android wall how to
    Hello,
    I'm assuming this is a type of app that you can enable/disable apps & services that run on your device?
    Usually you can disable anything safely without permanent damage. Most that seems to happen in the event you disable something that is required to run is you will get a " FC " or forced close error/pop up window when doing so. If that happens then just re enable the app/service.
    Granted when you try to disable certain apps especially system apps you will generally get a warning window saying it can affect the device and its performance.
  3. #3
    geekymcfly's Avatar
    Posts
    Global Posts
    951 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Marco Feijoo View Post
    Here is a list of deleted apps courtesy of Droid Views (user unknown)
    https://dl.dropboxusercontent.com/u/...20Note%203.txt
    Here is a more informative spreadsheet about what's safe and not safe to delete courtesy of
    perosredo of (XDA Developers)
    https://docs.google.com/spreadsheet/...=sharing#gid=0
  1. Replies: 14
    Last Post: 01-25-2017, 06:45 PM
  2. Astro Runner [Released] [Free] [Android]
    By Steven McStravog in forum Android Games
    Last Post: 06-10-2014, 01:28 PM
  3. Replies: 2
    Last Post: 06-02-2014, 11:49 PM
  4. Replies: 12
    Last Post: 05-30-2014, 11:21 AM
  5. How do I know what RUU I use?
    By natathaphol in forum HTC One Rooting, ROMs & Hacks
    Last Post: 05-29-2014, 08:19 PM
