Results 1 to 2 of 2
    Default Notification panel missing mobile data & MMS issues
    Is anyone else noticing that we do not have this button?
    anddd
    I just came off of the HTC Sensation to the S4. I never keep the data option enabled all day because of the battery drain, plus I just manually update all my sync'd apps anyway so there's no need for it to drain my battery & use up my pre paid credits at the same time.
    My problem is this. With the HTC Sensation is when I would go to either send or receive an MMS I wouldnt have to have my data connection permanently on. It would automatically enable the connection to send or recieve the incoming MMS, download the pic for me then automatically disconnect it when it was done. No muss no fuss. The GS4 does not automatically enable data to retrieve ur messages, you instead get a little download button in ur text you have to click. Is there anyway to make it like the HTC Sensation?
  2. #2
    Default Re: Notification panel missing mobile data & MMS issues
    I'm coming from the HTC Evo 3D (3vo) on Sprint.
    That phone required mobile data be turned on for MMS/pics (manually).
    The setup on your sensation seems solid. Wish that was more common.
  1. Mobile Data issue. Have to toggle to use
    By Pdelponte in forum AT&T Galaxy S3
    Last Post: 07-13-2012, 10:48 PM
  2. Virgin Mobile MMS Issues Thread
    By icemank121 in forum Virgin Mobile Optimus V
    Last Post: 01-23-2012, 06:27 AM
  3. Mobile data issue after wrong SW update
    By chisholm in forum Virgin Mobile Optimus V
    Last Post: 10-11-2011, 05:17 PM
  4. Mobile Data issues...
    By Vudumedic in forum Verizon Droid Incredible
    Last Post: 10-30-2010, 03:27 PM
  5. Nation wide T-Mobile data issues?
    By ILoveBlythe in forum Google / HTC Nexus One
    Last Post: 01-29-2010, 01:58 PM
