Results 1 to 10 of 10
Like Tree1Likes
  • 1 Post By geoffropuff
  • 1 Post By dk1492
    Mihir Bhatt's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default T-Mobile Galaxy S4: Pick up calls and auto hang up problem.
    Hi, i have a s4 and lately its been playing up, when i answer a call it immediately hangs up. I then have to call the person back.
    I don't know what the problem is, i even googled it and couldn't find anything relevant. So i thought i write a thread on a forum.
    Please can someone help me?
    Thanks
  2. #2
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Default Re: Pick up calls and auto hang up problem.
    Quote Originally Posted by Mihir Bhatt View Post
    Thanks
    Welcome to Android Central
    How are you answering the calls? Regular swipe to answer or are you using the "AirCall Accept" option?
    Sent from my Galaxy S4 running SlimKat 4.4.2
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thank you
    Regular swipe
  4. #4
    UJ95x's Avatar
    Retired Ambassador
    Posts
    Global Posts
    10,442 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock 6.0.1
    Thank you
    Regular swipe
    Does it hang up as soon as you answer or is it happening after you put it up to you ear?
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: T-Mobile Galaxy S4: Pick up calls and auto hang up problem.
    As soon as I answer
  6. #6
    canadiancrab's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am having this same issue.. its really killing me that anything to do with this issue, there are literally no responses to.. ANYWHERE on these forums..if anyone knows what on earth is going on- can you PLEASE help?? I have even posted a new thread and gotten NO REPlys..
    Its quite annerving when one cannot even use their "smartphone" to do simple phone tasks!!! im here trying to consult with the experts...is anyone willing to help??
    Plz....HELP!!
  7. #7
    geoffropuff's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    I am also having this issue. I have a Verizon Galaxy S4. I've noticed that when my phone rings, it'll have the stock android incoming call screen (black screen with blue bar at the top, and circular icon to drag to answer the phone. After I drag to answer, it doesn't pick up but instead opens the touchwiz incoming call screen. Once I answer from that screen, the phone waits until I say, "Hello" and then hangs up immediately.
    Is this similar to other people's experiences? I don't really know how to go about looking for help since it's such a strange situation.
    Diego Jim likes this.
  8. #8
    Diego Jim's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Thumbs up Re: T-Mobile Galaxy S4: Pick up calls and auto hang up problem. WORKAROUND
    *android s4 problem, call ends call is hanged up after being answered*
    Scenario
    Any Call triggers a CIRCLE type input. After swiping to the right the call does not begin immediately, instead, it opens up a HORIZONTAL BAR type of swipe. Instinctively, you will try to swipe right a second time to answer your call.
    This causes the call to be answered, remain open for about 3 seconds, then hangup.
    Problem
    There is a conflict overlap with the phonecall UI. By accepting the call in two different UI's, the calls is terminated shortly after being picked up.
    WORKAROUND:
    When receiving an incoming call, answer it normally with the CIRCLE-type input by swiping right.
    If the Touchwiz horizontal type screen is shown, ignore it, do not interact with it.
    The call will take around 3 seconds to begin, but once it does, all will be ok and the auto-hangup will not take place.
    CAUSE:
    Unknown. But started to happen since June/July 2014.
    Fix/solution
    Not determined yet.
  9. #9
    jolie420's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Is this still a problem for anyone else?
    I can't answer any call with any setting.
    Swiping hangs up.
    Home key hangs up.
    HELP
  10. #10
    dk1492's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    did you ever get an answer to your problem?
    Liza Rivera likes this.
  1. Veteran Note owner. 1, 2 and now 3!
    By HothTron in forum Samsung Galaxy Note 3
    Last Post: 03-12-2014, 08:17 PM
  2. Replies: 18
    Last Post: 03-11-2014, 01:49 AM
  3. Verizon Galaxy S4: Bootloader and roms
    By ferndchamp in forum Samsung Galaxy S4 Rooting, ROMs & Hacks
    Last Post: 03-11-2014, 12:45 AM
  4. Sprint LG G2: Can you direct me to roms and a recovery?
    By Justin Cardwell in forum Sprint LG G2
    Last Post: 03-09-2014, 08:06 PM
  5. SMS and MMS very laggy
    By speedtrip in forum Android 4.4 KitKat
    Last Post: 03-07-2014, 07:08 PM
