I'm having odd issues with Bluetooth voice control that I can't seem to find an answer to through all of my Googling.
I just installed a new head unit in my car, an Alpine UTE-52BT. The phone streams audio through the Bluetooth connection just fine, and it seems to work just find for hands-free calls, too.
The issue is that the microphone sometimes won't listen when I attempt voice control. Holding down the button on the radio invokes voice control, and I can choose to launch either S Voice or Google,since I haven't chosen a default. S Voice never seems to pick anything up from the microphone in the car or in the phone while it is connected. Google is odd, because it brings up the Now screen and it will activate listening when I say "OK Google", but at that point the mic almost always stops responding. If I have never connected power while connected to the car, the car mic will frequently listen, but once I plug in power it tends to go back not not responding, except for "OK Google". I'm running out of ideas for what else to change--I've heard that on the S3 enabling/disabling touch sounds can have an affect, but I haven't had any luck with that yet.
Thanks for any advice!
