1. Rirruto's Avatar
    I've just encountered a strange and frustrating issue that began a couple of days ago on 7/12. I have a Galaxy S4 running 4.4.2 and a 2010 Nissan Altima. I've had my car for 4 years and have never had this issue with any of my phones until this past Saturday so I am convinced it is my phone that is the issue. The Bluetooth pairing will connect without issues (indicator on both phone and car screen indicates so) and I am able to make/receive a call with sound successfully for one time. If I a make or receive a second call, there will be no sound both on my end or the caller on the other end. I know the call connects since the call timer starts on both my phone and the car screen as well as on the caller's phone (tested out with my wife's phone while in the car). I will not even hear a ring tone, the call will just connect without sound. Even if I disconnect the Bluetooth connection, there will not be any sound coming from my handset and the caller on the other end cannot hear me when trying to perform a call. The issue can be temporarily fixed with a phone restart. After making one successful call after a phone restart, the no sound issue will return. I'm not sure what to do at this point. I've re-done the phone pairing with my phone and car but the issue resurfaces. I see somebody posted a very similar issue on a different website on the same exact day I started getting the issue (Can only hear phone calls on Bluetooth) so I am wondering if we got some sort of app update that has started to interfere with Bluetooth connections. Any advice would be appreciated. Thanks.
    gene7oh likes this.
    07-15-2014 10:11 AM
  2. DarwinsFlinch's Avatar
    Same issue here with S4 and Plantronics earbuds (my phone and wife's). Not found a resolution... you?
    07-28-2014 01:51 PM
  3. DarwinsFlinch's Avatar
    RESOLVED: Your comment in another section tipped me off. I, too, enabled "Ok, Google" from any screen. Disabled it and the problem is no more. Glad you got yours going as well!
    hubermania likes this.
    07-28-2014 02:07 PM
  1. Does AVG give false notifications of sim card changes on android?
    By stalemate1 in forum Android Security Talk
    Last Post: 02-10-2015, 09:30 AM
  2. Sprint M8 Updated with WiFi Calling
    By Almeuit in forum HTC One M8
    Last Post: 12-23-2014, 01:13 AM
  3. Device is silenced when using BT HF in car
    Last Post: 07-17-2014, 04:55 PM
  4. Phone logs and SAS messages
    By cadguy59 in forum Motorola Droid MAXX
    Last Post: 07-15-2014, 06:25 PM
  5. Lockscreen time incorrect after sleep
    By mav1c in forum Verizon Galaxy S III
    Last Post: 07-15-2014, 09:50 AM
