1. wolfman7828's Avatar
    What is this ip service that is running in the background causing my battery to drain. Stock kit kat
    07-31-2014 04:51 AM
  2. warn joe's Avatar
    Well, I guess it is an internal android ecosystem programme running to detect the IP address ! I guess can't confirmed it but its sure that its an internal android ecosystem process. It usually keep on working while you have activated data connections.
    07-31-2014 05:30 AM
  3. wolfman7828's Avatar
    Wonder why it just started being a big battery drain recently. Guess I'll have to figure out which app is triggering it to run so much. Judging by the awake time that was when I disconnected from wifi and started running on mobile data.
    07-31-2014 07:51 AM
  4. wolfman7828's Avatar
    Not sure why this picture didn’t upload with the first one.
    07-31-2014 06:16 PM
  5. warn joe's Avatar
    Well, tell me did you recent update your device ??? I mean on which KitKat version of Android you currently are ??
    08-01-2014 01:13 AM
  6. wolfman7828's Avatar
    Yes I did update it to the kit kat software a few weeks ago and everything has been working great. I went into the main settings and applications and force close that ipservice and haven't had an issue since then.
    08-01-2014 05:35 PM
  1. Note 8.0 Overheating and battery drain after KitKat update.
    By felloffthetruck in forum Samsung Galaxy Note 8.0
    Last Post: 11-30-2016, 05:39 PM
  2. Replies: 74
    Last Post: 11-15-2016, 04:29 AM
  3. Media Server Using Battery Whilst Playing Spotify
    By tshirttan408 in forum HTC One M8
    Last Post: 08-01-2014, 01:46 AM
  4. dead batteries and no connection to computer
    Last Post: 07-30-2014, 05:50 PM
  5. Spare Battery and charger for the S5
    By jmagid51 in forum Samsung Galaxy S5
    Last Post: 07-30-2014, 02:32 PM
