Hello everybody, i installed a few days ago a software update wich was arround 300mb, and i did it over WiFi. After the update NFC and S Beam are.. well ...screwed !! My phone is not rooted. So the ON/OFF buttons in settings are greyed out. And in the battery settings NFC uses about 5 % to 20% it varies. I did a factory reset and still the problems are there. I don't use NFC, i haven't installed any apps for it. I think that the software update just screwed them. I installed NFC Check by Tapkey and it say it's deativated, but in the battery usage it shows NFC 4%. Hope you guys can help !
