Results 1 to 3 of 3
    Default One Click Lag Fix Help.
    Ive downloaded the one click lag fix from the market.
    I installed the EXT2 Tools.
    When i tried to install the lag fix i get the error: "You do not have /system/bin/playlogos1....
    I tried the restore boot animation but it also failed.
    Anyone know how i fix this?
    Thank you.
  2. #2
    Default
    I recommend against using OCLF. It is outdated and no longer supported by the developer.
    Root your phone and then flash any custom kernel. You can enable the lag fix from CWM after that.
    Bell Moto Atrix
    Rooted and 100% Bloatware free
    HSUPA Enabled
    ROM: U4_2.1.1
  3. #3
    r3g
    r3g is offline
    r3g's Avatar
    Posts
    Global Posts
    372 Global Posts
    Default
    Quote Originally Posted by GibMcFragger View Post
    True story. You want to be using the Voodoo lagfix which is current and EXT4.
