Results 1 to 3 of 3
    RTEK's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Installed wrong kernel, dont know how to fix
    I was trying to install the Voodoo kernel. I had the stock+froyo one installed just fine using Odin3. Then I went to their main page, and saw the 5.5 version. Titled Voodoo lagfix for Froyo stable. I used Odin to install it from the Download Mode. everything went fine till the voice said something about not enough space on the partition.
    Then the T-Mobile pink screen appears, then the Samsung Vibrant S screen, then it goes black. Nothing happens after that except the bottom lights come on if I touch them. Odin3 still sees my phone as plugged in. I have a really hard time trying to get into the Recovery screen, but when I do, I have no idea what to do once I'm there.
    I've tried using Odin3+Download Mode to reinstall the stock+voodoo-froyo-t959-UVKA6.tar which worked fine the first time, but I can never get back to the main home screen.
    Any advice would be much appreciated, I'll be online for the next few hours refreshing this page, so my responses should be fairly quick. Thank you in advance.
    Update: I tried searching for solutions, came across this
    http://www.samsungvibrantforum.com/c...msung-vibrant/
    I followed the instructions, everything worked as intended, until after the S screen, I just got a black screen. Never went to the home screen. This where I am currently at.
  2. #2
    ls377's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Teamhacksung's ICS
    Default
    Quote Originally Posted by RTEK View Post
    Samsung Vibrant - How To: Install and use Odin3 with the Samsung Vibrant
    It doesn't loop? Odd. Try it again, sounds like a bad kernel flash.
  3. #3
    devgru82's Avatar
    Posts
    Global Posts
    157 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Tried them all...
    Default
    Have you tried using this:
    [PROGRAM] AIO Vibrant Toolbox 2.5 *Beginners Start Here* Also for advanced users - xda-developers
