Results 1 to 8 of 8
    Default samsung is fixing the lag issue
    i posted and comment on there facebook page about the lag on the vibrant and they said this
    Samsung Galaxy S wrote:
    "Hi, Ed. We hear your comments, and please know that we are diligentliy working on this issue. Thank you for your patience."
    So thats someting anyway. I did the very easy lag fix on mine and it defently makes a big diffenece my quadrant score before was somewhere around 900 and now it between 1700 and 2102 big diffence.
  2. #2
    thebizz's Avatar
    phone addict
    Posts
    Global Posts
    3,578 Global Posts
    ROM
    mean
    Default
    Well looking at the euro model they have already implemented changes to fix the lagg with that I have no doubt that when Froyo launches they will push the changes into that
    Rooted for life
  3. #3
    Default
    here's the easy lag fix that works, i did it last night, quadrant score went from 8-900 to over 2000. definitely worth it. fyi when you run the LagFix1024.sh script to create the 1gb file, it takes a decent amount of time (i didnt time it but ~5-10 min?) be patient. everything's fine.
  4. #4
    Default
    Camrs, how does the improvement in speed help the keyboard, if at all? I notice there's lag when typing, and sometimes missed letters. Does the fix help these issues, or just on screen smoothness?
  5. #5
    Default
    And do you need to root your phone to do this lag fix?
  6. #6
    Default
    i use the stock android keyboard and there's a noticeable improvement. seems like the limiting factor is how fast i can move my thumbs. not only is the screen transitions smoother, they're faster, also apps load much faster, the market loads almost immediately, and the phone boots up faster too.
    and yes you need to root
  7. #7
    Default
    Quote Originally Posted by thebizz View Post
    Just another example of how Samsung supports Europe, but fails mightily in Asia and the U.S.
  8. #8
    thebizz's Avatar
    phone addict
    Posts
    Global Posts
    3,578 Global Posts
    ROM
    mean
    Default
    ^^ How is that exactly how long has the phone been out in Europe let alone the fact that the update has to pass through the carrier before you are it. And for all we know the carrier may not want to use the bandwidth and push it out with Froyo on the way. With a rom for the captivate leaking that reportedly improves the responsiveness off the phone I can bet Samsung is working on it for the us.
    Rooted for life
