1. mgaf63's Avatar
    I originally set my ringtone to android and set it as default. Now I want to use Zedge, but I don't have the option under my settings. How do I reset my default?
    06-02-2011 07:21 AM
  2. b0ricuaguerrero's Avatar
    they should pop up autmatically when you look at the ringtones from the settings. or you can uses zedge to set the ringtone if you want
    07-10-2011 07:48 PM
  3. vinaykrypton's Avatar
    Thank,s for this . Thanks from Outsourcing Android Mobile Application Development
    Team, KryptonSoft, India
    08-30-2011 03:11 AM
