1. owenmc60's Avatar
    Hi,
    I'm due to go on holiday later this year to Las Vegas (coming from the UK). The best tariff I've found is T-Mobile PAYG. I currently have a Samsung Galaxy S3 (i9300), which, as far as I'm aware, isn't compatible with T-Mobile's US network.
    I'm looking to sell this handset just before I leave and pick up a cheap budget Android off eBay that is definitely compatible with T-Mobile whilst I'm in Las Vegas. Can someone inform me of both some good cheap options and the bands that T-Mobile specifically uses for USA/Las Vegas?
    Thanks alot in advance
    01-14-2014 03:30 AM
  2. dpham00's Avatar
    The s3 i9300 should work on tmobile. In Las Vegas, you should be able to get voice and up to 4g speeds since Las Vegas is a refarmed area
    Sent from my Verizon Samsung Galaxy Note 3 via Tapatalk Pro
    01-14-2014 07:56 AM
  3. owenmc60's Avatar
    Thanks for that info. I wasn't aware that the S3 (i9300) works in Vegas on T-Mobile. Out of interested what does a 'refarmed area' refer to? Cheers!
    01-14-2014 09:49 AM
  4. IAmSixNine's Avatar
    T-Mobile has taken 1900mhz spectrum and re-farmed it so to speak to work with its network. You should get HSDPA+ or LTE speeds IF your device is capable of that in the specific band.
    I cant speak as to the coverage because im not in that geographical location so hopefully someone there can chime in.
    01-14-2014 10:14 AM
  5. dpham00's Avatar
    I9300 doesn't support 4GLTE.
    01-14-2014 12:34 PM
  6. GadgetGator's Avatar
    Hi,
    When you say cheap what range are you talking?
    01-15-2014 08:45 PM
  1. Paranoid Android KitKat
    By JohnBB101 in forum Nexus 4 Rooting, ROMs, & Hacks
    Last Post: 01-26-2014, 10:55 AM
  2. mobile data
    By iRevo in forum General Help and How To
    Last Post: 01-14-2014, 04:01 PM
  3. cropping in bbm?
    By Wessun in forum Samsung Galaxy S4
    Last Post: 01-14-2014, 02:19 PM
  4. Music apps which save metadata to file
    By inhumangeek in forum General Help and How To
    Last Post: 01-14-2014, 03:01 AM
